Tanabe Sustec Coilover Question
i am considering suspension mods. i was probably gonna go with the tanabe's, but does anyone know if there is a big difference between the pro and pro type II kit?
Bye TSX, hello domestic?
Originally Posted by supraken
Anyone care to explain what is a helper spring and what does it do?
i don't think you'd actually benefit from the helper spring much unless you were going over sand dunes or something
ABP TSX
I do not think you need the helper spring for regular street use. IMO, it is more of a marketing gimmick.
From Tanabe
"Helper springs assist with rebound stability, ride comfort and keep the main coil spring seated. Preload of the main spring can also be set to zero, for maximum comfort and suspension travel."
http://www.tanabe-usa.com/coilovers/s-s.asp
From Tanabe
Former Sponsor
Xizor explained the function of the helper spring well and it is the main difference between the Type I and the Type II. The Type I has the helper spring. Helper springs basically assist with rebound stability, ride comfort and keep the main coil spring seated. The Type I also has a slightly shorter spring than the Type II.
If you need either or let me know. I am an Official Vendor for Acurazine and a direct Tanabe dealer.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 07:42 PM
