Suggestions for new tires
Proud Acura Owner
I found these and a few others on tire rack, but overall these have good ratings across the tire rack survey reviews.
http://www.tirerack.com/tires/tires....nSpeedRating=V
looking to spend around 100 bucks per tire.
i just need them for average everyday driving. i live in central NJ, but only drive locally usually or on the parkway or local highways for about 10-15 miles a day.
No room in
I don't have any experience with them, but for what it's worth, I also ended up with those as my first choice for stock replacement all-seasons after poring over tire selection on TireRack. If they live up to the ratings I don't see how you can beat the bang for the buck - the two tires that are rated higher in that category are $155 each
The General Exclaim UHP is available in the OE size now and I doubt you could beat it for the money (it was rated and I assume still is #1 in its' survey category). TireRack always sold this as a summer tire (they may still, I don't know) but it's actually rated (and marked) all season. I've had a few sets of these, and although I've only used them as summer tires (I'm a firm believer in a set of 4 dedicated winter tires), if I were going to go the all season route, I'd stick with them.
Proud Acura Owner
and the main thing is that the dunlops have solid tirerack survey ratings across the board. so thats good.
just one question, one reviewer on tirerack said that the tires caused their fuel economy to drop in a honda civic?
i have a 2004 tsx, so maybe that was just a car-specific issue for that one person.
i mean i will definitely look at some other tires for comparison before i buy.
Proud Acura Owner
but it says those tires are not good in icy and freezing temps. i live in NJ, so in the winter, you never know what this weather can bring. From March to October, those generals will be fine. but come nov-january, i might have problems driving through ice and snow.
im looking for all-season tires, not summer tires.
the dunlops are only 11 bucks more each at $107.00, so i might just go with those and get all-season tires.
Someone stole "My Garage"
I've had 2 sets of Dunlops on other cars and they were both crap (in wet weather, and for treadwear).
I have the General Exclaim UHP's on my TSX now and will DEFINITELY buy another set in a few years. They are awesome. I also put them on my wifes' car as well last week and she loves 'em as well.
Wet-weather is their best improvement over OEM, and dry handling, noise, and comfort are all very, very impressive. I have them in the slightly wider and shorter 225/45-17 and couldn't be happier, especially for the price.
thanks
dm
No room in
I doubt there would be a significant difference. The wider tread and stiffer sidewall might have slightly better grip and turn-in flex, but otherwise I'd expect it to be pretty much comparable. The Generals are rated very well at Tire Rack. I ordered them on my new wheels in 235/40R18, but I just got them today so I won't have them mounted until the weekend
Last year the 215/50-17 weren't available in the UHP's. I do believe the 225/45's are slightly lighter as they're only rated SL (standard load) as opposed to the 215/50 which are XL (extra load). Technically our TSX calls for XL tires but many, many members are running SL's with a few psi extra, without any problems whatsoever.
I prefer the slightly wider (225) width as it gives a bit better grip, and the shorter sidewall (45) means less sidewall flex.
Proud Acura Owner
well im not trying to alter any of the car's default specs.
im just a normal driver, not an enthusiast or racer or anything.
i just want tires for around a 100 bucks each that give me a little better performance than the stock michelins i have.
CL9 ABP
You can go with the exclaim but their summer rated tires so you don't get much mileage, better look at all seasons.
I had the exclaim as summer tires their great, although the sidewalls are quite weak which scare me and had a few replacements already. Poor mileage for summer was hoping for more but they are summer rated tires.
so we can go up to 225 on the stock rims for an 04 with no problems?
gistered User
I do like the Falkens 912 (30k mileage warrantee) on my stock rims. Good dry/wet handling, quiet, comfortable. I'm also a 'joysey boy' and, snow/ice handling is not a forte of this tire. However, good, sensible driving skills in winter; will see you through. At @ $95 a tire–shipped from Discount Tire Direct, its hard to beat.
I've run both the Falkens and the Generals, and though they're both good tires, I found the Falkens to be much noisier (and old technology; they were rated number 1 by Consumer Reports like 10 years ago). And I will repeat that the General UHP is actually an all season tire (if you doubt me, check their website)(and anyone that actually has a set, just check the sidewall). Tire Rack markets them as an "Ultra High Performance Summer" (the name would indicate as much I guess: "Exclaim UHP") tire and I'm not making any claims about their winter performance. One key difference though, is that since they're not in reality a summer tire, if nothing else, they don't turn in to hockey pucks at 25 degrees.
I have the UHP's and can attest first hand to the fact that they are a soft rubber compound and DO firm up considerably below 7*C / 45*F or so. I can feel the bounciness (park when warm, overnight they cool off and firm up and cause flat spots). It goes away within 1km or so, once the tires start to heat up.
I would NEVER run these in snow deeper than 1cm. And definately not over any slick (icy) roads.
An "All Season" rating has absolutely nothing to do with the rubber, ONLY the tread pattern. Basically, a percentage of the tread must be voids to move water/slush (which is why racing slicks, no matter what the rubber they might want to use, will never get the "M+S" rating signifying all-season).
gistered User
M+S marking on tires is very misleading.
Many AWD tires are rated M+S, M&S or M/S, i.e., mud and snow. Established by the USA Rubber Manufacturers Association (RMA), the M+S designation refers only to the tread pattern. The M+S standard calls for a tire with grooves at the outside of the tread that extend into the centre. It also means that 25% of the tire tread contact surface be open, i.e., a more open tread pattern.
You will find the M+S symbol on most all-season tires, on off-road and all-terrain tires and even some high performance summer tires may have this designation. However, there are no performance standards to meet or traction tests to pass. Any tyre with grooves at angles and with 25% of the tread void can be labelled as M+S.
Aside from the M+S designation, and the severe winter designation (the mountain/snowflake), there is NO RATING for all season tires. It was conceived by the manufacturers, not a ratings organization, and technically you could use a tire with a racing compound rubber but as long as it had the grooves and 25% open area, it'd be considered M+S. And any tire, even a racing slick, could be labelled "all season", because there's no reprimand for doing so -- it's just a label with no legal basis.
A year ago I was leaning towards a set of Avons but now, based on what I've read on Tirerack and the reviews herein, I think I'm going to take a shot at the Generals. I'm at 44K mi. on the OEM set and still have a little tread left but the noise they generate is becoming unbearable.
edit: Actually I'm still torn between the General UHP and the Yoko Avid V.
This is my first post to this forum but I have read numerous threads... I just got Falken 912s size 225/45/17 on the stock rims and I have had noticeable vibrations on the highway from speeds 50+. I can feel the vibrations in my seat not just in the steering wheel. I bought the tires from Mavis Discount Tire. I complained about this issue and went back and had them re balanced twice. Which has not fixed the problem. Could the larger size tire be causing the vibrations? Or are they still not balancing it properly. If any of you guys have any ideas i would really appreciate a response. On a lighter note, I have noticed improved handling and grip especially on wet roads.
I had a set of Falken 512's before that more than one of the tires was out-of-round. No matter how much it said it was 'balanced', it was still a rolling oval. I won't buy Falken's again after that (and a piss-poor treadlife experience as well).
Jack up a corner, spin the tire, and see if it bulges or seems wonky. That would be a potential area to get a replacement tire free-of-charge as a manufacturers defect.
I have the General Exclaims in 225/40/18 and they are an improvement in all areas over OEM. Sure there are better tires than these, but for the money, the Exclaims cannot be beat on value.
I live in California so I have no idea how these handle in cold weather, but if you want a budget performer and don't live where it gets too cold, I'd get the Generals.
I was actually torn between the yoko s.drives and these, but the s.drives were out of stock so i thought i'd give these a try.
I did notice that the sidewall was a little softer than what I would want, but nothing too bad. Maybe I'm running too low of a PSI or something.
Old Man Yelling at Clouds
Anyone here try the General Altimax HP? I just looked up the Exclaim UHP's and after reading the comments I don't like what's being said about snow. It does snow here 1-2 times per season. The Altimax has outstanding reviews - comparable to the Pole Positions I was planning to get, but they're ~$50 cheaper per tire. I'm close to replacing and I'm now thinking the Generals...
saberlove
03-11-2021 09:29 AM
