A-Spec suspension, extra nuts?
Old Mar 12, 2009 | 12:26 PM
gftgrill's Avatar
I got my A-Spec suspension in the mail yesterday, I'm looking at the instructions.
the set came with 2 extra nuts which are in the instructions, but they don't say what they are supposed to replace.
so my question is what are these nuts for? this is for an 06 6mt.
thanks
Old Mar 12, 2009 | 02:57 PM
Worth's Avatar
Those nuts (I think they are called the king nut) go on the large bolt that goes through the bottom of the "coilover" and connect it to the rest of the suspension. There is only one place it can go. They have plastic inside them so you're not supposed to reuse the original ones. There is a really good diy thread on here for the install that I used. Search is your friend
Old Mar 12, 2009 | 04:29 PM
gftgrill's Avatar
the DIY talks about the extra nuts, but they say that it should have a plastic ring in them. the nuts that I received do not have a plastic ring in them.
did they change these nuts when they changed parts from the 04-05 to 06-08?
Old Mar 12, 2009 | 07:52 PM
Worth's Avatar
i have an 06 6MT too and i dont think the replacement nuts had plastic, just the original ones...
Old Mar 14, 2009 | 12:14 PM
HataMoto's Avatar
3rd Gear
Those are new Damper fork pinch bolts. They are for the front damper fork. just replace the ones you remove with the new bolts . step 5 in the install instructions.
Any other questions, I just did the install about two weeks ago. It takes alot of muscle i was sore for a week after doing it. took me about 5 1/2 hrs.
Old Mar 16, 2009 | 01:56 AM
acura_ak's Avatar
I did mine a while ago and it wasn't as quick as I thought it would be. I actually took almost 6 hours. To me it was a pain, but the end result is worth it.
Old Mar 16, 2009 | 08:26 AM
JTso's Avatar
Some oem nuts have nylon inserts and some use crimped end for self-locking. The nuts in the pics above use crimped end. You can clearly see the crimped marks and slightly deformed end.
Old Mar 16, 2009 | 07:15 PM
HataMoto's Avatar
3rd Gear
Your right is actually took me about 6 hrs, I did not want to seem like a wussy!
MrHeeltoe
20
Feb 23, 2023 01:54 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
adreano17
Sep 29, 2015 08:48 AM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
