A- Spec setup
A- Spec setup
Hey all!
I am looking for some input on a set-up I am thinking of doing. I would like to either put 19 X 7.5 RJ Inspyre with 225/35/19 with an A-Spec suspension or 18 X 8.5 RJ Inspyre with 235/40/18 with A-Spec suspension. I am just looking for a nice and clean ride, not too much of a "slammed" look. What do you all recommend I should do?
Is it possible to do 19s with 235/40/19 with the same suspension setup? Will there be any rubbing on any of those set-ups? I am planning on putting a sub box in the trunk and occasionally with have about 4 people in the car.
Any input would greatly be appreciated
You're getting 7.5" wide rims in either 18" or 19" diameters, right? I wouldn't run 8.5" wide rims.
There are forum members running 235-40-18s and 235-35-19s. Neither will rub with RonJons as long are you are getting the 7.5" +50 offset rims.
Since you are planning on putting a sub box in the trunk, I would consider some height adjustable suspension rather than the A-spec. Otherwise, the back end would look too low compared to the front. This will be exacerbated by having 4 people in the car.
Originally Posted by virtualbong
I never considered this factor with the A-Spec. I think you may have sold me on the Eibach Pro-Kit.
Unless you had adjustable-height dampers and adjusted them to compensate for the added payload that is.
Originally Posted by rmpage
Wouldn't the same thing be capable of happening with the Pro-kit though?
But with the Eibach Pro Kit at least its 1.6" in the front and 1.4" in the rear...maybe I'm just trying to make excuses to get the Pro Kit instead of the A-Spec because I like the drop more...decisions, decisions.
In a way, that's why I went w/ the Comptech 110-155 springs w/ Neuspeed Konis. I was comfortable w/ the amt of lowering the A-spec gave in the back, but from a purely cosmetic standpoint, I wanted the front to be dropped a bit more for the slightly raked forward look. The Konis give me that flexibility to adjust ride height front and rear to suit my taste.
Originally Posted by GrOD
Thank you for your input. Yes, I am planning on getting 7.5' rims but I haven't really decided on either 18s or 19s. What do you suggest would be better? I really don't want to compromise too much of the ride.
I foresee a Pro-System set up in your future. From reading your posts, I don't think you'd be happy w/ the mild A-spec drop regardless of whether you will have a subwoofer box in the trunk or not.
And, yes, I should just get the Pro Kit setup. I just wish Tire Rack didn't get me all excited about the Eibach Pro-System Kit. I guess I'm going to cancel that order and get the Eibach Springs instead. Do you guys think I should go with Eibach Pro Kit with stock shocks until the Eibach Dampeners come out or should I just get the Koni Yellows?
Where are you from? How are your roads? Since you want to maintain ride quality, I'd go with 235-40-18s. Besides, Ron Jon rims tend to look pretty big b/c of their design (spokes run right up to the edge of the rim w/o a lip. This type of design tends to make the rim look bigger than a comparable sized rim w/ a lip. Therefore, Ron Jon 18s would look as big as some 19s.
How much was that setup?
I say try the Pro-kits with the stock shocks. At most, you might have to wait 2-3 mos for the Pro-dampers. If the car doesn't ride how you like during that time, you can always just buy the Konis.
I bought the Comptech 110-155s from forum member kaikai used for $140. I got the Neuspeed Konis online for $580 shipped. So, total was $720. I chose the Comptech springs b/c they only lower the car about 1". I only want to lower my car about 1.25" front and 1" rear.
Personally it looks like I may be getting the Neuspeed sport springs and Neuspeed Konis unless something else comes up. Maybe like some TEINs with an EDFC!
So the Comptechs are only slightly more aggressive than the A-spec springs, am I reading you right?
The current version of Comptech's springs are part# 110-160. These are made by Eibach for Comptech and, though no one has really confirmed this, I am pretty sure that they have identical spring rates to the Eibach Pro-kits as they give about the same amt of lowering as the Pro-kits (1.6" F, 1.4" R).
An option that is not really discussed all that much on this forum is the Mugen set up. Like the A-spec suspension, it is sold as a complete spring/shock/upper mount unit. I think the Mugen's spring rates and damping are a bit firmer than the A-spec set up. But, the Mugen suspension is $1000 vs. $600 for the A-spec. I would consider the Mugen suspension if you are looking for something a bit more agressive than A-spec. The lowering is still pretty mild - about 1.25" all around.
I bought my Neuspeed Konis through ebay. The seller is asw88. He has 100% good feedback. The seller was great. He responds to e-mails immediately and I got my shocks in less than 24 hrs after ordering.
Found the link for you:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Actually, forget the A-Spec. I just cancelled my order with Tire Rack for the Eibach Pro-System Kit and won the ebay auction for the Neuspeed Konis!!! Now, someone please tell me the cheapest place to get the Eibach Pro Kit. Thanks!
btw. I'm so glad I finally made a decision about my suspension, LOL
stuff.
dzuy - how do the TEIN Flex dampers feel in terms of ride quality? Also, what springs are you using with them? I don't know much about those parts at all, really.
...now I just have to wait to see the side A-Spec pics from another member before making a decision
Originally Posted by bigwilliestyle
Hey Bong, congrats on your decision! Did you still get the pics? Can you post them?
You can get A-spec suspension from Acura of Escondido. They sell it for about $600 on e-bay. Remember to get the right one for your car as they come in automatic and manual versions.
Here's the link to the auto version:
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V
Here's the link if you have a manual TSX:
emailnatec
29
09-28-2018 04:27 PM
