SPC vs Ingalls, vs Eibach vs Comptech Camber kits
Not sure which rear camber kit to get for the TSX. I ordered the Eibach Pro System from Tire Rack and was notified it would ship out May 20th. Just getting the parts together for the car so when I take delivery of the car I can start modding away.
I know SPC and Eibach are the same kits. I heard Ingalls are difficult to adjust. Im pretty much between the SPC and Ingalls, but dont know the difference.
If anyone has worked with both could enlighten me on this subject. If SPC is the way to go, I'll just get the Eibach version for brand loyalty and consistency on the suspension components.
Comptech is also SPC.
Ingalls replaces two of the lower control arms, easy to install, maybe a little more time consuming to adjust but not hard.
After reading of rusting problems and leaky seals on SPC, I opted for Ingalls..........
Don't know if you searched yet, but here is the thread I started about my install. Ingalls give the necessary toe adjustment whereas SPC does not.
https://acurazine.com/forums/showthr...t=21623&page=1
Luke 1:37
My alignment guy said the Ingalls were great and very easy to adjust. Max 15 min. to do the alignment.
Ingalls is the way to go if you install it yourself as well. Very simple install.
If you use the Ingalls, you would use the adjustment on the rear rod for toe. If you use the SPC, you would use the factory toe adjustment on the eccentric cam. Both kits accomplish the same common goal - camber. The SPC requires only two arms for both sides, whereas the Ingalls requires 4. The SPC requires a ball joint tool, whereas the Ingalls requires only simple hand tools. Adjustment is similar on both. They both require camber and toe adjustment after the installation.
Thanks for all the comments guys. Now this is why I appreciate a TSX board with members like this. Looks like Im going with Ingalls.
Moda Way I saw your post a week or so back, great info! LannyM thanks for the warning about the SPC problems.
Originally Posted by JTso
FYI...
Got Milk???
SPC here, so far so good. Both toe and camber are adjusted to factory specs easily. Taking it in next week again to adjust rear camber to -0.5 to give the car more of a balance front to back.
-KC
-KC
FYI...
...The SPC requires only two arms for both sides, whereas the Ingalls requires 4.
Ive decided to go with Ingalls. Glad to know they allow the camber and toe adjustment all in one. Decided to pick up a set on ebay for $139+ship =$149
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
From what Ive read so far on the forums I dont need a front camber kit since the factory parts can adjust for camber?
Originally Posted by arch
Not sure what you meant by this. Two arms vs four, an extra mechanic or extra parts.
For those of you with SPCs on the rear, aside from needing a pickle fork, how difficult was it to get to the bolt on the inside of the arm?
When I used to have the SPC, I don't remember any difficulty getting to the bolts. However, removing the bolts to the brake line supporting bracket and shift the bracket aside did help the installation process.
Got Milk???
Originally Posted by MyK24a
whats the optimum camber settings for street use? I have yet to get a camber kit and running a -2 camber on the rear after using Espelir lowering springs
It depends on how low your drop is. I'm sitting on Eibach Prokit 1.6"F 1.4"R, front camber is -0.9 after drop. Naturally you'd want more negative camber in the front on a FWD to reduce understeer therefore keeping the car more balanced. Currently my car is at -0.9 front and -0.5 rear and I'm loving it so far.
-KC
Bye TSX, hello domestic?
Both accomplish the goal of aligning your system to spec, Ingalls has no downsides IMO while the SPC can a PITB (need ball joint remover, not built for toe adjustment, etc.). So just by ease of use I'd choose Ingalls.
Just dial 1911
1 Post
-KC
-KC
Does anyone know if the stock TSX 215/50/17 tire will work on the 17x8 TL tires or will I need to shop for a tire combo also?
Got Milk???
Exactly what Im about to go with! Can I ask what kind of shocks are you using? Next thing to do is find a set of 04/05 TL rims.
here is the link to some pics of my car with TL rims
https://acurazine.com/forums/showthread.php?t=20901
-KC
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
