skunk 2 coilover sleeves problem please help
Old Sep 10, 2010 | 04:52 AM
erupt323's Avatar
Ok guys tday I install my skunk 2 coilover sleeves but for some reason my car still looks high even when the sleeve spinning thingy is all the way Down and I followed all instructions on install I have stock struts and idk if that is the problem Also I just notice my shock iS blown and it makes a loud thump please help
Old Sep 10, 2010 | 12:43 PM
xaznperswaesonx's Avatar
tear it apart and start over. normally with your problem, seems to be a install error, like front spring is installed in the rear and/or adjustable perch is at the wrong location. Or they sent you the wrong part.
Since your shocks are blown, might as well order aftermarket shocks. oem shock are basically same price. don't know how many shocks are blown, but if one shock is blown, you replace that and the other side as in sets. typically if front right is blown, front left is heading towards that direction as well.
If you do plan to get aftermarket shocks and retain your skunk coilover sleeve, I highly recommend the Konis.
Old Sep 11, 2010 | 01:10 AM
erupt323's Avatar
yea um plannin on getting coilover set
Old Sep 11, 2010 | 01:21 AM
if your plan is to get the coil over set .. ya might as well return it, if you still can .. if not sell it, and buy the coil over set.
SidhuSaaB
May 30, 2020 12:40 AM
eastsideride
Oct 15, 2015 04:26 AM
Matthew Purpura
Sep 25, 2015 06:10 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
4drviper
Sep 23, 2015 07:42 PM
