Seeking Expertise..
Is waiting in
Seeking Expertise..
My current wheels are TL A-Spec. When I bought them off of eBay, the seller listed them as 18x8, so I kept my eye on them and I won them. However, when I received them and inspected them, they were actually 18x8.5. Now this makes my life a lot more difficult.
My questions to you all:
- How low can I go without rubbing?
- Tein H.Tech 1.1 F 0.7 R, will that be a decent drop?
- Will I HAVE to roll the front fenders and pull the rear for anything lower?
- My coilover preferences are either the Tanabe Sustecs (which I heard are absolutely great) or to order the Tein Comfort Sport
Received 3,789 Likes
we need a picture from the front to see how far they stick out towards the edge of the fender. also what is the offset
Bye TSX, hello domestic?
the offset is +45, and those wheels probably already stick out a little bit in the front. honestly the 18x8.5 wheels are a bad starting point, but since you've already gone done this road you're stuck.
i'd say the fronts are more likely to rub, and w/o a bit of camber front and back both will rub if you go much lower. IMO i think any wheels will work w/ 1.6/1/4in drop. But the beauty of coilovers is that you can adjust it till its just right.
I'd advise against rolling your fenders b/c the paint on the fenders will crack very easily! you can do little things like move your fender liner inside the fender to gain a couple mm
Originally Posted by feelgood13
8.5's? you should be thinking lift kits, not coilovers..
so how much camber would you need to run to fit an 8.5 +45 offset wheel.
Originally Posted by PJS
Depends purely on the amount dropped. Probably fine up to 1.5 or 1.75", after that, then you're likely to start needing camber adjusters installed.
I want to tuck atleast 1/4 inch of tire maybe more. I know I have to run some negative camber but what I am asking is if you thinkg it will need to be a lot.
The best thing I can think of would be to talk to some of the companies who make camber kits, specific suspension kits, and the stores (online/bricks & mortar) who've done enough R&D and trial and error.
They'd be the ones I'd ask advice from before going any further with the idea.
depends on your offset really, I don't know how much camber is necessary
the offset is 45 and the wheels are 8.5
Is waiting in
thanks for the excellent advice, i really appreciate it.. going to make a call to my friend to see if he can get me the TEINs, if not i will contact Marcus
DANG!! 8.5's AND a low offset? might as well throw on some bubbled purple tint, some chrome fender trim and apply for residency in mexico...
DerrickW
20
09-27-2015 02:45 PM
oo7spy
Technology
26
09-22-2015 10:01 AM
