Rotate tires at home.
I'm thinking about rotating my tires myself, but I only ahve one jack and two stands. Should I ditch the stands and grab some bricks to take off all four wheels at teh same time? or should I use the stands? HOw do you rotate your tires yourself?
The simplest way, if you intend to do it yourself, is to have the car on a level surface and jack all four wheels off the ground using the front and back jacking points and four jack stands. Never use bricks or cinder blocks to support a car -- they're not strong enough.
Four stands and a jack will also come in handy if you want to change your own manual tranny oil (if you have a 6mt).
cool thanks. I jacked up my car today but I found it hard to get the jack stand to get under the jacking point because the base of the jack stand was too wide and it got in the way of jack I had.
Kinda like this:
__ <~ jacking point
| / \ <~jack stand
| Jack
Kinda like this:
__ <~ jacking point
| / \ <~jack stand
| Jack
well the way I rotate my tires (just front to back), I break the lugs loose, then jack the front by the sub-frame from the front of the car, place the jack stand under the jacking point on the desired side.
Then I jack the rear up, on the frame from the side of the car and place the jack stand on the rear jacking point.
Swap tires and the rest should be self explanitory.
Note: It is a lil more diff. for me, since my car is lowred, I assume urs is stock height.
Good Luck!
Good Luck!
Kinda like this:
__ <~ jacking point
| / \ <~jack stand
| Jack
Kinda like this:
__ <~ jacking point
| / \ <~jack stand
| Jack
Get the proper jack and stands and use the correct support points. Stay away from using bricks and cinder blocks to support the car as they are not safe. You can potentially pay for it with your life if you take shortcuts in safety, even when performing simple tasks.
Originally Posted by dereksmalls
It's actually easier if you place your jack under the front, central jacking point, raise the entire front of the car
I've done the front each side at a time wa stand, then used the central jack point in the back (the bracket under the spare tire area - told to me by Acura service manager) to rotate my wheels. I know that I should put stands under the back but I just left the jack hold up the rear wheels while I did the rotation.
Originally Posted by MattJP
Where is the central jacking point to raise the entire front??
mugen_kid
11-13-2015 10:38 PM
Oakes
Wash & Wax
10-12-2015 11:17 AM
