RonJon Devotion-1pF, 19" front / 20" rear, lotsapics!!
So I had two prototypes of each diameter, and My sister had a TSX loaner for a few hours while her car got service. took advantage and got these mounted and shot. these are not really stagered, they just look it, but they are both 8.,5" wide. 19" will fit the front and rear fine, BBk or OEM brakes. 20" will fit front and rear fine as well, no rubbing, just tucking, but only with OEM brakes. Don't mind the Stock suspension, it was a loaner. i plan to shoot the TSX once more when we get the production pieces in. here are a few weights i measured when everything was on hand as well:
20" x 8.5" w/ 225/35/20: 45lbs
19" x 8.5" w/ 225/35/19: 44lbs
18" x 8" w/ 235/40/18: 39 lbs
all the above are sample wheels in polished finish with a little more weight to be taken off before prodcution.
17" x 7" w/ 215/50/17: 47 lbs
Stock wheel and tire for TSX.
Pretty damn good for 20" wheels to be 2 lbs lighter than stock 17" wheels and tires.
18" wheel and tire are almost 10 lbs lighter per wheel and look a ton better than 17"!
here is the web page with all the needed info:
http://ronjonwheels.com/devotion1pf.html
Damn I want the 18" rims. I still have the stock rims on mine. How much will performance/acceleration increase due to the decreased weight of the 18" rims versus the stock rims... or will the larger size rim offset any performance gain?
its all up there, just scroll up and read before the pics, here it is again:
Originally Posted by GSGOMEZ
Damn, that's nice wheel but $$$$.
Originally Posted by rondog
20" forged wheels that look like this and weigh less than 17" stockers come at a decent price. I could have made them less $$ but then they wouldn't weigh what they doo, or be as strong. Definetly worth the extra cost in the long run.
Originally Posted by Big Pimpin
Ron would you ever consider black rim with polished lip?
Missin my TSX =(
HEY RONDOG .... how are those prototype body kits goin for the tsx? i would love to see them actually produced like the TLs.... keep us updates
sorry for thread jacking
Luke 1:37
Originally Posted by LOL888
is that white tsx stock ride height?
"... Don't mind the Stock suspension, it was a loaner...."
TSX Sold! Hello STi!
Wheels look great --- generally not a big full chrome/polished wheel guy, but these bad boys look dope!
What are the specs on the lip widths for each size?
What I mean is that if you drop the TSX 3" or very low, the 20" wheels with 225/35/20 will clear the fender wheel well without rubbing, and will tuck. I haven't had a chance to calculate camber, but none is need to clear, it clears as is.
Front 19" lip is 1.25" due to BBK caliper clearance, the rear 20" lip is 2.25" and they don't clear BBK, but they clear the OEm brakes just fine.
Thanks Neil for the drops, imagine a Bodykit too! here is a banner for the site with a nice drop too:
Originally Posted by amadeus303
Ron... when you say "just tucking" regarding the 20" set, do you mean you have to run negative camber in the back to keep from rubbing?
That new wheel came with black with polished lip. Check it out: http://www.ronjonwheels.com/ronjonim.../devo_cl15.jpg
jmoney2001
08-12-2019 06:23 PM
