Rim Size Help
Rim Size Help
i got a 06 tsx navi and ive been wanting to put some wheels on it. it has the 17 inch apsec wheels on it now. i am puttin 20's on it! bottom line. i dont care how monster truckish its gonna look.
but i want the TIS 07's the question is should i get 20x7.5 or 20x8.5???? and will a 35 series tire work??? the site is reccomending 30 series
if you dont have any positive input please dont bother replyin. thanks
Modding newbie
Putting my personal oppinions away for the moment, you can make anything from a 25 to a 40 series tire work, it depends on your width. You can also make a 7.5 or an 8.5 inch wheel work just fine too.
You could go with a 205/35/20 if you want a 35 series tire, or with a 225/30/20 if you want a 30 series tire. Either way you're going to have the same sidewall size so it doesn't matter which you pick, it'll look the same. If you want, go with a 175/40/20 or a 275/25/20 and you'll still have the same size sidewall despite the different aspect ratios. Though they'll all work (if you can find a tire in that size) I'd suggest the 225/30/20. It'll be ugly, but you'll have just about the same outside dimensions as a stock tire, but the 20 inch wheels you want. With a 225 tire, I think 8.5 is a your only option as 7.5 is too small right?
Modding newbie
7.5s will probably be lighter so you'll have that benefit. The tires will look more "stretched" out on an 8.5 than a 7.5. Other than that, nope, there's no other pros or cons.
ExcelerateRep
10-14-2015 08:20 AM
