Planning to buy a new set of tires
I am planning to replace my current OEM tires with a set of Yokohama AVS ES100. The thing is I am still deciding on the sizes. 215/50/17 or 225/45/17. If I go for the 225/45/17 that will create a larger wheel gap compare to stock, I will lowered the car but not for the time being. I need some advise on choosing the right sizes.
Go Dutch !
Don't know what's wrong with the car in that thread, but it really looks jacked up or on 16". I've got the option wheels from Honda which came with a 225/45ZR17 Michelin Pilot Sport tyre. Wheelgap is not as bad as the blue TSX.
For comparison :
Still need to get it lowered though (next week with the Pro-kit). I personally think that after lowering the 225/45/17 will look better than your stock 215/50/17 size...
For comparison :
![](http://memimage.cardomain.com/member_images/2/web/218000-218999/218435_28_full.jpg)
![](http://img43.photobucket.com/albums/v132/mokijoki/Cars/S3010011.jpg)
Sile
Originally Posted by AcuraTSX2004
The 225's will be about 1/2 inch smaller than the 215's but only create an extra 1/4 inch gap between the top of the tire and the wheel well -- right?
Bye TSX, hello domestic?
well I think he means up and down, not in and out spacing. w/ a 1/2" difference, 1/4" is on the top, the other 1/4" is on the bottom. So yes, as far as wheel gap goes, only half of it shows on the top.
Baka Unco
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
Go Badgers!
Can someone post a close up pictures of the stock rim with 225/45 rubber (without lowered) ....I would like to compare with the 215/50 rubber to see the differences oo the wheel gap. Thanks
Here's my car with 225/45/17 Toyo T1-S. I should mention that according to the T1-S spec sheet, they are a bit taller than the average 225/45/17 tire, but based on my measurements on the TSX I'd have to disagree. I suspect that the specs would match only when using a 7.5" rim (TSX's are 7.0") and at the tire's max cold PSI.
Profile:
![](http://memimage.cardomain.com/member_images/12/web/648000-648999/648612_3_full.jpg)
Rear:
Front:
Profile:
Rear:
![](http://memimage.cardomain.com/member_images/12/web/648000-648999/648612_1_full.jpg)
Front:
![](http://memimage.cardomain.com/member_images/12/web/648000-648999/648612_2_full.jpg)
Here's a great tire size calculator to compare multiple tire sizes at once.
TLDude876
12-28-2016 03:18 PM
