is this offset safe??
Old Apr 15, 2008 | 04:41 PM
stegon78's Avatar
My choice of wheels only comes in 19x8 with +38 offset, I plan to install 225/35/19 on it. My car is currently dropped with tein H-tech springs (around 1" drop front and back.) Will I run into clearance problem with this offset??
Old Apr 15, 2008 | 04:57 PM
MMsTSX's Avatar
JDM Addict
yes, and no.
well first off, I'm no expert, so this is just opinion.
okay.
yes, you'll have a problem.
the offset is too low and your wheels will be sticking out.
the 225 tire will help a bit, due to the light stretching you'll do to get them on there.
but still, the wheel will probably stick out.
no, you probably won't rub.
if you have a 1" drop, you still have at least an inch or two clearance all the way
around, and that should be just enough.
might look a bit odd though.
this is my best guess/opinion.
Old Apr 15, 2008 | 11:26 PM
msmching's Avatar
Ex-King of Pasadena
no matter what.. isnt it better to be +42 offset for our tsx?
or shld i say, we HAVE to put on one that has +42 offset?
Old Apr 17, 2008 | 12:31 AM
Big Pimpin's Avatar
I have +42 offset and it looks perfect I think any lower it will stick out too much
Old Apr 18, 2008 | 04:12 AM
S14 n Tsx's Avatar
mmmmmm....
+42 is perfect. I think 19x8 +38 is going to require camber and right size tires to have it running. I would be running 19x8 +42 so...
neuronbob
23
Jul 16, 2019 10:48 AM
SinCityTLX
55
Oct 11, 2015 01:20 AM
MilanoRedDashR
Oct 2, 2015 10:49 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
4drviper
Sep 23, 2015 07:42 PM
