Offset Question
Offset Question
I found a good deal on some clean Bronze Volk TE37's, they are only 17's but I know they will still look clean being that I have a PWP TSX. The only thing is the rims have an offset of +32 will this have a negative effect on the rims fitting my car properly or will there be a need for spacers or anything of that nature. I think that the stock TSX rims have an offset of +42 or +45 not sure. Rims are 17x7.5. Thanks for any response to this post
The +32 offset will make the rims stick out past the wheel well. They will definitely rub.
Adding spacers will not increase the offset number. It will *reduce* the offset number which will make the rims stick out even further. If you add a 5 mm spacer, the wheel is spaced out 5mm more which means you will now have a +27 offset which will be sticking out past the wheel well pretty far.
Bottom line is, don't get these rims for your TSX.
Got Milk???
for a 7.5" wide rim, best offset would be +42
I have 18x7.5 45mm offset and it slightly tucks under the fender
32mm offset is way too low, that'd probably put too much stress on wheel bearings
-kc
-kc
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
