NSX front wheels?
NSX front wheels?
The NSX front wheels starting MY 2002 were 17X7, 5X114.3. They were also forged and significantly lighter than the TSX OEMs. The only difference I can identify in size specs is centerbore: NSX front 70.1, TSX 64.1. Hub rings should be able to make these wheels hubcentric for a TSX, shouldn't they? Has anyone done this or know for certain whether or not it will work?
Offset is identical, +55mm. It appears, though, that hub rings in the correct size to make these hubcentric - 70.1 outer diameter, 64.1 inner - are not common. Also, people with older NSXs that want to put on wheels from the later models have had issues with brake caliper clearance.
Driver/Detailer
Advanced.
A quick search and I found these rep's. http://www.finishlinewheels.com/ACURA/NSX/2002/
アコードタイプSとくれば、喜びもひとし お。思わず投
how much do those NSX wheels weigh?
Advanced.
http://www./tech/wheel_weights.html
http://www.gti-vr6.net/library/wheel...wheels_weight/
rockyboy
01-25-2016 06:00 PM
mtl_ilx
09-03-2015 09:58 PM
nuldabz
09-03-2015 05:49 PM
