Need some serious help with suspension
I am going to get a suspension setup in a few weeks (hopefully) but am unable to get a clear response. I was thinking about the Tein type Flex, and i hate to repost but am seeing conflicting reports in the forums:
Dzuy said:
“the stiffest setting is way too harsh on the road. it handles great tho.
the softest setting is perfect for normal street driving. handles as well as it did, if not slightly better, than the car w/ the eibach pro kits. but driving experience is improved over pro kit/stock shock combo. def. not as bouncy.”
TechSX said:
“I have the Tein Flex at setting #8 front and #6 rear (16 levels total). The suspension is really stiff no matter what setting its on. I had a set on a 99 Civic Si, and now my second set on the TSX w/ EDFC, both are harsh. “
along with
“No pain, no gain. However for the less extreme drivers out there that just want the look, I highly recommend springs over a full coilover set”
Can i get some more opinions here so i don't end up hating my suspension setup??
btw my other consideration is koni yellows w/ a pro kit....so comments on the ride quality of that would also be helpful
along with
It depends with model of Flex you are getting. The US spec Flex p/n is DSA64-6USS4 has 783 lbs F & 488 lbs R spring rates. The JDM spec Flex p/n DSA42-61SS1 has 559 lbs F & 336 lbs R spring rates, which is the same as the US spec SS or Basic.
and yes, I have used the search, but nobody seems to have directly compared those two, and...as shown by my initial post...there may be differing opinions on the same product
Originally Posted by madmanmax3000
Alright then I would say I am one question away from a decision....which is more comfortable ride quality....Konis with Pro Kit, or Tein type Flex?
https://acurazine.com/forums/showthr...t=20493&page=2
He states Pro-kits are comfortable, but due to the progressive nature of the spring, he thought it was difficult to find a good overall damping level with the Konis.
FWIW, I personally don't think high spring rates alone necessarily means poor ride quality. I think the compression damping of a shock plays a greater part. When it comes to Japanese shocks (Tokicos, GABs, KYB-AGX) I have found that they tend to have too much compression damping. To make matters worse, it seems like their damping adjustment increases BOTH compression and rebound or just compression alone. Thus, when paired with stiff springs, the ride quality is harsh.
OTOH, with Koni sports, when you run a stiffer and lower spring, increasing the rebound damping will simultanouesly decrease the compression damping. This makes sense as the stiffer spring will not need further compression damping since the stiffer spring will already be harder to compress by virtue of its higher spring rate. What you do need is increased rebound damping to control the stronger rebound of the stiffer spring. Koni shocks seem to do just that. This is probably why most cars I've driven or riden in with Konis have good ride quality.
thanks AlterZgo, wish we still had the rep point system...so i think konis and pro kit are the way to go
if n e body wants to stop me, lemme know in the next 24 hours or so
Also, you can buy the Neuspeed Konis for about $550 on e-bay. Search for "Neuspeed Koni" and look for the TSX application. The e-bay seller is "asw88".
Virtualbong, there are two shops around the boston area.... PF Modify is one, but the one that i have used a couple times before is Wheel Dynamix. They are in Natick, its a very small shop but they have some nice guys there who know what they are doing. Hopefully they can get the Neuspeed version of the konis that AlterZgo mentioned for us. Here's their site...
http://www.wheeldynamix.com/
oh, and xizor....can i install the konis without the pillowball mounts?
and AlterZgo, the konis you mentioned...are those any different from the koni yellows other than more height notches?
Konis do not come with pillowball mounts. They use the stock upper mounts so you would disassemble the stock shock and spring assembly, take the stock upper mounts and install them with the Konis and Eibach springs.
The Neuspeed Konis also have a 20 mm shorter shock piston which is designed to work better on a lowered car.
I just received my Neuspeed Konis this past week. They are made by Koni and is a Koni branded product. Other than the differences noted, they are pretty much identical to the non-Neuspeed Koni sport shocks. I don't know for sure, but I believe that the compression and rebound damping are the same. Regardless, both have adjustable damping.
I see that they also sell wheels, so if you want to work together to get a good deal, then I'm up for that. I'd be interested in seeing how much for Koni Yellows and Eibach Pro Kit there, plus some wheels, so if they knew that we were getting all this stuff from them, I'm thinking they should try to accomodate us by giving us a decent deal. Let me know if you want to work something out.
I just emailed those guys from Wheel Dynamix and their prices are about $200 more than what you can get online. Here's the email (notice the bold):
Wil,
First the easy stuff. The wheels and tires.
The volcano's will cost you $1500 with the tires.
The enkei rp03s will cost you $1900 with the tires.
The rpo2s are discontinued.
The suspension will cost you for the parts only including camber kits for
the front which I highly recommend will cost you $1245.
Everything at this time is in stock!
Thank you for the opportunity to quote you.
jeff
-----Original Message-----
From: wil_kwong@hotmail.com [mailto:wil_kwong@hotmail.com]
Sent: Monday, March 14, 2005 10:17 AM
To: sales@wheeldynamix.com; pk@infinitydesignstudios.com
Subject: Wheel Dynamix INFO REQUEST
The following online information request has been generated.
Phone:
E-mail: wil_kwong@hotmail.com
Below are any comments they submitted:
I was referred to you guys from a friend. I was wondering what kind of deal
would I be able to get if I were to purchase multiple items from you guys
and maybe have 1 or 2 other people interested in purchasing some stuff at
the same time. But for me, I have a 2005 Acura TSX and I would like to
purchase the Eibach Pro Kit Lowering Springs, Koni Yellow Shocks, and maybe
a wheel package if you guys were able to offer me a good deal on the entire
package. I would be interested in 18x7.5\" TSW Volcanos or maybe Enkei
RP02s or Enkei RP03s matched with some Falken Ziex 512s in 235/40/18s.
Please let me know the estimated cost for each item if I were to get
everything as a package deal. Thank you!
Wil,
jeff
Phone:
hmm...i just don't know of a better place to have it done, and i'm sure as hell not gonna attempt this myself
PF Modify, according to their site, is in the process of moving their shop, but they don't seem to have mentioned where to, and its been that way for a month....do you know anything about what became of them?
I can recommend the neuspeed/koni with Comptech 110-160 springs.
These springs are said to be made by Eibach, identical to prokit? I don't know.
The drop is the same.
My ride quality is good. It can get hard on really rough roads but that is
going to happen on any suspension. Right off the top the springs are soft
enough and then get harder. I don't have any problem with damping.
The rebound is fine no oscillations. I'm using 1-5/8 front turn and 3/4 rear
turn on the shocks.
I was already at a point where my car needed the koni's even on stock
springs, this happen after putting on 225/40-18's.
I just put Tokiko on my wife's van, and it is
harsher on bumbs than mine. Too much compression damping, mine is fine.
The front drop is about 1.75", rear 1.5. My bottom will touch on rediculous
high speed bumbs. I hope that will be fixed next with 235/40-18 vs current 225/40-18.
turn on the shocks.
oh and virtualbong, i'm not sure if you missed it, but your name isnt on the list...there is a meeting at F1Boston coming up mid may, you should come
here's the link to the thread...
https://acurazine.com/forums/showthr...17#post3963717
i still prefer my tein flex over the pro kit. the ride is a lot tighter.
i now have my front and rear set at 12, with 16 being full soft.
my car is sitting a lil too low for the 19's, it does rub occasionallly. but i dont have any time to adjust the height, so i'm keeping it.
if you get the pro kits, i would suggest buying aftermarket shocks and def a rear camber kit.
speakin of camber kits, where has stiffy been?
i seriously recommend you getting either the Buddy Club racing spec dampers.. or the tein flex's.. both coilovers. you might want to adjust it in the future whether its for looks or performance. you will be spending a lot of money already with the spring plus shocks combo.. might as well go for some nice coilovers.. my
i was interested in the tein flex's but didn't want to sacrifice that much ride quality, therefore i will go with the konis and pro kit
MrHeeltoe
20
02-23-2023 01:54 PM
lanechanger
10-13-2015 10:56 AM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
