Max tire width on existing rims...?
Hi all:
While I'm pretty sure one could go up to 225/50s on the existing 17" rims, do you think it's possible to go up to 235/50s or 235/45s on the existing rims?
I actually really think the stock rims look great on this car, but the wheels beg for wider rubber to give the car a more aggressive, Audi A4-like stance.
Anyone have any experience with this?
Thanks,
Gundar
Thanks,
Gundar
It really depends on the specific tires recommendation. USUALLY 225/45 is the widest you'd want to go on a 7" wide rim but there are a few exceptions.
One exception is that the larger the sidewall is, the wider tire will more easily fit onto the rim. Example: most 235/45-17 tires recommend at least a 7.5" wide rim while most 235/40-18 tires recommend at least an 8" wide rim. If one were to go from 235/45-17 to 235/50-17 the tire with the aspect ratio of 50 would have a minimum rim width of 7" as opposed to the 7.5" min width for the 45 series tire.
Ayumi Hamasaki
hmmm... so If I go for an 18x8 rim would you reccomend the 225/40/18 or the 235/40/18? I never thought of going wider before, just now thought of that.
235/40/18 seems perfect for the TSX, since it has almost the same rolling diameter as stock (so your speedo and odo still read properly). Lung and maybe a few others have put 235/40/18s on their TSXs, so we know they don't rub. What remains to be seen is whether this setup can accomodate aftermarket lowering springs.
Registered AssHat
2006 DGP Sold 10/24/2012
Originally posted by Dan Martin
It's not recommended to go past 225 on the stock rims but some have gone to 235 without any trouble.
Santa Rosa Steve
Photography Nerd
I don't remember where this chart came from but if it belongs to someone here, tell me and I'll pass the credit along:
EDIT: It's from Yokohama's website: http://www.yokohamatire.com/utrimwidth.asp
Summary
Each tire has a specific rim width range on which the tire can be mounted. Failure to follow rim width recommendations may result in poor tire performance or possible wheel and/or tire failure.
Details
Below is a quick reference chart listing each tire size and the acceptable rim widths for that size. Choosing a wheel near the middle of the range will give a balance between ride quality and handling. A wider wheel will improve handling at the expense of ride quality, while a narrower wheel will improve ride quality at the expense of handling. Consider these compromises when selecting wheels.
35 Series
Tire Size Rim Width
275/35R17 9.0-10.5
335/35R17 11.0-13.0
345/35R15 11.0-13.5
40 Series
Tire Size Rim Width
285/40R15 11.0-13.5
215/40R15 7.0-8.5
245/40R17 8.0-9.5
255/40R17 8.5-10.0
265/40R17 8.5-10.0
235/40R18 8.0-9.5
45 Series
Tire Size Rim Width
195/45R15 6.5-7.5
215/45R15 7.0-8.5
255/45R15 8.5-10.0
205/45R16 7.0
225/45R16 7.5-9.0
245/45R16 8.0-9.5
215/45R17 7.0-8.5
235/45R17 8.0-9.5
255/45R17 8.5-10.5
50 Series
Tire Size Rim Width
175/50R13 5.0-6.0
195/50R14 5.5-7.0
205/50R15 5.5-7.5
215/50R15 6.0-7.5
225/50R15 6.0-8.0
195/50R16 5.5-7.0
205/50R16 5.5-7.5
225/50R16 6.0-8.0
235/50R16 6.5-8.5
215/50R17 6.5-7.5
55 Series
Tire Size Rim Width
205/55R14 5.5-7.5
185/55R15 6.0-6.5
195/55R15 5.5-7.0
205/55R15 5.5-7.5
205/55R16 5.5-7.5
225/55R16 6.0-8.0
60 Series
Tire Size Rim Width
185/60R13 5.0-6.5
205/60R13 5.5-7.5
185/60R14 5.0-6.5
195/60R14 5.5-7.0
205/60R14
195/60R15 5.5-7.0
205/60R15 5.5-7.5
215/60R15 6.0-7.5
225/60R15 6.0-8.0
235/60R15 6.5-8.5
65 Series
Tire Size Rim Width
185/65R15 5.0-6.5
195/65R15 5.5-7.0
205/65R15 5.5-7.5
215/65R15 6.0-7.5
70 Series
Tire Size Rim Width
165/70R10 4.5-5.5
175/70R12 5.0-6.0
175/70R13 5.0-6.0
205/45R16 7.0
185/70R13 5.0-6.5
185/70R14 5.0-6.5
195/70R15 5.5-7.0
205/70R14 5.5-7.5
185/70R15 5.0-6.5
205/70R15 5.5-7.5
215/70R15 6.0-7.5
82 Series
Tire Size Rim Width
155R12 4.0-5.0
155R13 4.0-5.5
165R13 4.0-5.5
175R14 4.5-6.0
185R14 4.5-6.0
165R15 4.0-5.5
Summary
Details
35 Series
Tire Size Rim Width
275/35R17 9.0-10.5
335/35R17 11.0-13.0
345/35R15 11.0-13.5
40 Series
Tire Size Rim Width
285/40R15 11.0-13.5
215/40R15 7.0-8.5
245/40R17 8.0-9.5
255/40R17 8.5-10.0
265/40R17 8.5-10.0
235/40R18 8.0-9.5
45 Series
Tire Size Rim Width
195/45R15 6.5-7.5
215/45R15 7.0-8.5
255/45R15 8.5-10.0
205/45R16 7.0
225/45R16 7.5-9.0
245/45R16 8.0-9.5
215/45R17 7.0-8.5
235/45R17 8.0-9.5
255/45R17 8.5-10.5
50 Series
Tire Size Rim Width
175/50R13 5.0-6.0
195/50R14 5.5-7.0
205/50R15 5.5-7.5
215/50R15 6.0-7.5
225/50R15 6.0-8.0
195/50R16 5.5-7.0
205/50R16 5.5-7.5
225/50R16 6.0-8.0
235/50R16 6.5-8.5
215/50R17 6.5-7.5
55 Series
Tire Size Rim Width
205/55R14 5.5-7.5
185/55R15 6.0-6.5
195/55R15 5.5-7.0
205/55R15 5.5-7.5
205/55R16 5.5-7.5
225/55R16 6.0-8.0
60 Series
Tire Size Rim Width
185/60R13 5.0-6.5
205/60R13 5.5-7.5
185/60R14 5.0-6.5
195/60R14 5.5-7.0
205/60R14
195/60R15 5.5-7.0
205/60R15 5.5-7.5
215/60R15 6.0-7.5
225/60R15 6.0-8.0
235/60R15 6.5-8.5
65 Series
Tire Size Rim Width
185/65R15 5.0-6.5
195/65R15 5.5-7.0
205/65R15 5.5-7.5
215/65R15 6.0-7.5
70 Series
Tire Size Rim Width
165/70R10 4.5-5.5
175/70R12 5.0-6.0
175/70R13 5.0-6.0
205/45R16 7.0
185/70R13 5.0-6.5
185/70R14 5.0-6.5
195/70R15 5.5-7.0
205/70R14 5.5-7.5
185/70R15 5.0-6.5
205/70R15 5.5-7.5
215/70R15 6.0-7.5
82 Series
Tire Size Rim Width
155R12 4.0-5.0
155R13 4.0-5.5
165R13 4.0-5.5
175R14 4.5-6.0
185R14 4.5-6.0
165R15 4.0-5.5
235/45 would bulge out too much on a 7" wide rim. The sidewall is not designed to be run like that.
Santa Rosa Steve
Photography Nerd
Steve, I'm sure you can get them mounted but i would be weary of putting it on a rim that’s one full inch smaller than the minimum width that the tire manufacturers recommend.
No problem mounting at all.
There is a possiblity other brand P235 could look wider.
They are not all the same, exactly 235 mm wide.
I would confirm actual tire width and compare to the Pirelli
before selecting another brand P235.
I laid a straight edge across the side and measured
depth to the wheel rim, it is .25", stock is .15" ( I think
you can confirm). .25" is not abnormal.
Tim
Tim
".25" is not abnormal."
LOL, that same measurement on my 215/50-17 SZ50's is 3/8", which are wider than the original tires in the same size.
"I would confirm actual tire width and compare to the Pirelli
before selecting another brand P235."
Good advice, Tim.
Santa Rosa Steve
Good advice, Tim.
Santa Rosa Steve
Tim,
How's the Pirelli PZero Neros overall? Quiet, nice ride, good performance? I'm in FL so I could care less about snow traction but would need some good rain performance at times.
Thanks,
Scott
Thanks,
Scott
Originally posted by AsahiToro
Tim,
Thanks,
Scott
Tim,
Thanks,
Scott
are excelent. I can take turns hard and pitch the car
violently with these, never had that confidence with the
Michelins. I also have the comtech rear bar.
They look to last a long time.
I have never broke them loose dry.
They will slip in hard cornering wet.
I wanted them because they are not unidirectional
and can be rotated side to side.
I am having ride disturbances. They flat spot when cold
and can take a longtime to smooth out.
I sent one back for pulling. It was on the rear and then
the car started pulling hard when I moved it up front.
Another is having balance vibration, it actually feels
worse on the rear. I might send it back, had it rebalanced
once but no help. On the front is vibrates the steering wheel
and on the back I feel it in my seat.
Ayumi Hamasaki
Originally posted by Lung Fu Mo Shi
Go with 235's definitely. An 8" rim can probably accomodate a 245 as well.
Wess
