Ingalls rear camber/toe adjustment kit. :)
i got it monday, put the arms in last night, and ran down this morning and got it aligned.
the arms:
![](http://builtb16a.com/camber/arms.jpg)
a front shot:
![](http://builtb16a.com/camber/front.jpg)
a rear shot:
![](http://builtb16a.com/camber/back.jpg)
and the spec sheet:
![](http://builtb16a.com/camber/specs.jpg)
the TSX doesn't have a caster adjustment for the fronts, so i'll have to live with that.. but for some reason, my right side front must be lower than the left, and this is leaving me out of spec in camber on the R-F.. not by much. its still in range, but almost on the verge of being out of spec.
the rears came out 100%. ide like to save my tires. =)
the arms:
a front shot:
a rear shot:
and the spec sheet:
NICE!! I just to mine installed this past saturday and monday. The bottom link for the toe was seized at one end so I had to have it removed at the place where I got my alignment. OUCh that wasnt cheap
But now I have them on and have lifetime alignments.
Have camera, will travel
the arms:
the arms:
Originally Posted by waTSX
What suspension-tire setup are you running?
Tein Super Streets.. coils at the top of the threads.. "the car can't go any higher.. lol" Volk 18" X 7.5" wheels, and 225/45R18's.
its a driving dream!
Received 3,750 Likes
its a driving dream!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
A DiRTBAG decal on my
why the heck do you have them all the way up thta seems to defeat the purpose of purchasing them in the first place.
Perhaps he likes the increased spring rates and a mild drop. Just because one has coilovers doesn't mean you gotta dump it
the main reason of getting Tein super streets.. and setting the coil perch about as high as it can go, is i don't want to have to worry about pot holes, or dips..
but i was parinoid of lowering springs, and getting the front higher than the rear, or an un even drop.
i might lower it a little next time i go in for an alignment.
thanks for the comments guys. alignments are they way to go though.. you can't loose paying a little extra, and always know your flying "straight".
you thought you were going to hit pot wholes at factory height so you raised the car is that what you are saying.
the only reason i got the tein's was the adjustable dampener.. and the fact i can adjsut the height front to rear.. adn not have the worry of getting a un-even lowring job.
Bye TSX, hello domestic?
Originally Posted by xizor
The SS as the highest setting is still lower than stock
i dont' understand how you would think its stock hight to beguin with. lol
if you laid the oem strut next to the Tein coil assembly, you'll find out the Tein is physicaly 2" shorter.. lol
Former Sponsor
well.. im glad you understand with the Tein's all the way up, its still noticably lowered.. lol
I have been racking my brain trying to figure out how your car is set as high as possible, yet it looks so low. I just realized it is the tires making it look that way. Your tires are actually 1/2" taller than stock, so your car actually LOOKS 1/4" lower than it is if you look at the tire gap....
could be very true marcus.. but i would of thought with the coil over susspension, i would still be able to get it alittle higher than it is now...
either way.. were it sits now.. is about where im gunna end up leaving it.
the perpouse in Tein coil over's are because i didn't want an uneven drop.. ive seen TOO many lowering springs make the front higher than the rear.. i wasnt' about to make that mistake.
Former Sponsor
The highest you can go is still 1.5" down in the front and 1" down in the back. If you are at the highest setting now, it still looks a little low. But the wheels and tires make it really deceiving.
How does it ride?
How does it ride?
How does it ride?
the ride is great!
Originally Posted by ianS
Do we need 2 arms per wheel or only 1 arm per wheel?
http://www.ingallseng.com/parts/38725.htm
^^ Good point JTso. I bought mine from www.importhorizons.com and they set 1 kit, which is both sides. The details are in the fine print.
Former Sponsor
what? no, i bought the Tein suspension.. but i don't want it too low.. so i have the tien's as high as they go. in reality.. maybe a 1.5" drop. which i belive tien's will go down to 3.5".
See, I just installed Ingalls camber kits and Tein SS on an 06 TSX this morning.
Here is where the rear height was set (Teins recommended spec). Right in the middle of the threads, with about .75-1 " to go up or down.
![](http://www.heeltoeauto.com/personal/misc/06-ss_01.jpg)
Here is what the car looks like:
![](http://www.heeltoeauto.com/personal/misc/06-ss_02.jpg)
And here is the tire gap:
![](http://www.heeltoeauto.com/personal/misc/06-ss_03.jpg)
I just don't see how your sus can be all the way up and still be that low.
Marcus
Marcus
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
3rd pic is on the rack.
i didn't look to see what part numbers were on the actual spring.. but when i recived the box from my distributor, it was unopened from Tein.
as you can see.. im pushing up on the coils, and can't get any play out of them.. they're as high as they can go by hand, and then some more by the spanner wrench.
the differance from 40 to 45 series shoudl'nt play that much of a role in how much gap... but in my opinion the tiens raised all the way up is still slammed.
i also have it aligned all the way around with only a rear camber kit, and the fronts on on the virge of being out of spec.
Here's my car w/ Tein SS on the very bottom of the adjustment, as low as it goes
![](http://static.flickr.com/41/110147068_ca55a5287b.jpg?v=0)
![](http://static.flickr.com/54/110147145_7b345660c1.jpg?v=0)
Former Sponsor
Well, then you made a very misleading statement. Just because you can't spin them up by hand any more does not mean that is not as high as the car will go. You have a lot of threads left and can raise that car at least 1/2"-3/4" higher. You need to preload the spring more to get it higher. How much did you preload it?
The difference from 40-45 series is not the issue. The issue is that your tires are 1/2" taller overall than you stock tires. That means you have your fender filled up 1/4" all around by bigger tires, making the car LOOK lower. Your car is not that low at all.
Camber means nothing. Lowering the car to any degree is going to mess up the camber. That is not a good way to guage the lowness of the car.
Marcus
the only way i think i could preload it more, is by using a spring compressor... and bringing the perch up higher. i gave them alot of good cranks with the tein spanner wrench.. thats about as high as it would go without using cheater bars, or something bigger.
