Include End Links w/ Sway Bar Upgrade (s)?
Old 03-19-2019, 10:50 PM
4th Gear
SakuSlam's Avatar
06' Stock daily driver TSK 5AT w/ 122k
Should I upgrade the end links (front and back) while I'm doing the sway bar(s)? Or just inspect them for longevity and decide then?
Also, for a 22mm sway: Just back or front as well?
Insight is much appreciated!
Old 03-20-2019, 12:09 PM
BROlando's Avatar
Received 1,184 Likes on 891 Posts
I don't think there are any endlinks that are an upgrade from the genuine Acura ones. Those are as good as its going to get (they're quite good).
If yours aren't worn, then leave them alone.
Pro tip...if you need new endlinks, order the fronts for a 2nd gen TSX and the rears for a 7th gen Accord. The fit is the same, but the cost is much lower for some reason. I use curryacuraparts and bernadiparts for OEM stuff.
SakuSlam (03-24-2019)
Old 03-20-2019, 04:36 PM
Reorge's Avatar
RockAuto.com has Premium/heavy duty end links listed for most Acura/Honda cars.
They look "beefier" in the product pictures but I don't have any experience in their performance.
Old 03-23-2019, 11:42 AM
4th Gear
SakuSlam's Avatar
Thank you gentlemen!
So 20-22mm is the goal and to reiterate, only doing the rear is good enough and adding a front would just be more work for a less marginal benefit?
Old 03-24-2019, 10:50 AM
BROlando's Avatar
The front bar requires removing the subframe. I felt that the rear bar by itself helped plant the car a little better.
Not sure how big of a difference the front bar makes. I'd maybe throw one on during a clutch swap...but I really couldn't be bothered to drop the subframe for JUST the bar install. Assuming this is just a street car being modded for fun?
sdwtchlvr
12-07-2020 04:16 PM
qwerty9119
04-28-2011 03:33 PM
StonedCL
04-22-2009 07:07 PM
NBPATL
10-01-2008 09:45 PM
big mike 13
10-28-2005 11:15 PM
Quick Reply: Include End Links w/ Sway Bar Upgrade (s)?
