Hub-Centric Ring - - - Help - - -
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
I recently just put on my VOLK GT-C's 18x8 on my 06 TSX.....after i get past 50 mph...my sterring wheels starts to shake horrbily. I am on Pzero Nero tires, so I know they are directional....I put the back wheels on the front and vice versa. The shaking is now minimal but annoying. I know there have been threads tryin to break down the problem...i read them. So basically this is more for rim specific:
a. what is another step to problem solve?
b. how can i get hubcentric rings that will fit these rims for an '06 tsx?
Bye TSX, hello domestic?
無限 本田 CL9
are the wheels balanced? you know those little weight that are taped to the wheels.. do you have those? if not, take it to a shop that does wheel balancing
i'll prolly try rebalancing...see if that fixes it.
so hub rings aren't rim specific or car specific? never bought a pair for any of my previous cars with rims
i don't have the pics on me...but i do have them up on myspace.com the name is under jose aspillera (germantown, md) i have some pics there, not good..but does the job.
Originally Posted by blacktsx05
is metal better or poly ones better?
Photography Nerd
Originally Posted by Newplay1
I have only used poly ones and they do bend/melt and useless after 1 summer..
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I think it all depends on what they're made of. There are many forms of plastic, and I'm sure some resist heat better than others.
Originally Posted by hawaiiantsx
what is the size of the hub on the car?
Most aftermarket wheels have a center bore of 73mm. My Volk GT-7's, Racing Hart CP-035's, and Spoon SW388's are all 73mm. So for the original poster, just buy a set of rings that have 73mm OD and 64.1mm ID. PM JoesTSX about the rings. He got me couple sets of rings already.
hey guys hubcentric rings are not needed. I never run them. But here is what you should do when putting on your wheels.
put the wheel on and keep it completly off the ground. Tighten all the lug nuts in a semi star pattern, get the lug nuts tight befor setting the car back down onto the ground. Once the car is on the make make your final run with the tq wrench.
doing this will get the wheels centered, on the hub and you will not need the hubcintric rings.
This site explains it better than I can in my tired & drunken state: http://www.moderntiredealer.com/t_in...t&storyID=1196
Just dial 1911
1 Post
cycdaniel
12-17-2019 10:58 AM
rmittal
1/2G MDX (2001-2013)
09-19-2015 08:41 PM
