Help With Skunk2 Pro-s
Old May 14, 2007 | 10:56 PM
sunny85's Avatar
Angry Help With Skunk2 Pro-s
So I just got my SKUNK2 PRO-S FULL SUSPENSION KIT installed on my 06 tsx and I am not happy I was thinking as its a coilovers I would have it dropped about 1" or so but detent happen the guy that installed it says that they where cranked up all the way but my rear wheel in badly tucked under the tire fender I have stock tires and was thinking if the coilovers jacked all the way up was meant to tuck the tire that much under the fender with stock tires. Could it be a bad set or just installed wrong or should I just pull them out and go with something different.
Old May 15, 2007 | 12:34 AM
daicacharco's Avatar
it must be installed wrong =X if you dont want them i'll buy them off of you ;]
im waiting to pick up my skunk2 coilovers too not the full suspension one though.
how do you like it though ? details about them ?
Old May 15, 2007 | 01:07 AM
WFC's Avatar
WFC
Ever heard of punctuation?
Old May 15, 2007 | 07:50 AM
Audioserf's Avatar
boost owns
I'm not sure I follow - you've tried adjusting the coilovers and still can't avoid tucking rear tire? That doesn't sound right, are you sure you're adjusting them correctly.
Old May 15, 2007 | 07:55 AM
Reach's Avatar
I get the feeling your garage monkey put them all the way down and thought he was putting them all the way up.
If you want something done right...
Old May 15, 2007 | 02:01 PM
arshu78's Avatar
Stop wasting space .....Don't just post anything irrelevant to this topic..Buy a KIA...they have enough time to play with your punctuation remarks.
Spring are bad........
Old May 15, 2007 | 02:08 PM
sunny85's Avatar
hey arshu78 why dont i just buy a Corolla and try to pimp it out like u did
Old May 15, 2007 | 02:20 PM
Reach's Avatar
Keep it clean fellers.
Old May 15, 2007 | 02:23 PM
so you get it worked out? also some details on the coilovers please !
Old May 15, 2007 | 03:59 PM
PJS's Avatar
PJS
Can you see the coilovers?
If so, is the adjusting ring all the way down or most of the way up.
If it's down, so more longer spring, there's the problem - you need to wind it up to preload the spring and raise the height of the car consequently.
If they are already most of the way up, then I'd have to assume the springs are not the rate they should be and you'll need Skunk2 to replace them - but for all 4 to be wrong (not impossible if it was a batch issue, but highly unlikely) would be a major eyebrow raiser.
If so, I'd be wanting them to do more than replace the springs, since you'll likely incur a second charge by the garage to strip and replace - and as it's not their fault, then they've no need to bear the cost.
But if they have the springs wound out fully, then that IS their mistake, and you shouldn't be out of pocket for them to rectify it.
Old May 15, 2007 | 04:00 PM
PJS's Avatar
PJS
www.skunk2.com - PDF brochure for you to read at your leisure.
Old May 15, 2007 | 07:21 PM
Tsx536's Avatar
Rep'n Taxbrain.com
I had some skunk coilvers on my old Civic. The spring rates were too aggressive and I didn't like them much. I remember that I could adjust to have about a 2 finger gap, but that was the max I could do without a spring compressor.
Old May 15, 2007 | 10:50 PM
chuson's Avatar
T.DoT P.I.M.P. lol
hey daicacharco...
either go for a FULL coilover setup, a-spec, or just aftermarket spring. Those skuck2 "coilovers" (half) does not worth your money... you can try, but I'm sure you will regret sooner or later... just an advice...
Old May 16, 2007 | 01:13 AM
WFC's Avatar
WFC
My point was, if you are going to ask a question, at least make it understandable. As far as wasting space, save your breath, because the same question has been asked over and over again on this forum.
Old May 16, 2007 | 02:42 AM
Originally Posted by chuson
hey daicacharco...
i got the koni yellow struts just to let you know -_-''
Old May 16, 2007 | 10:03 AM
chuson's Avatar
T.DoT P.I.M.P. lol
icic, that's good. But what's the reason for you to go for those skunk2 half coilover instead of gettting some progressive spring???
Old May 16, 2007 | 12:44 PM
decided to go with more of a drop. i have Tanabe DF210 springs right now that im selling on friday.
its my 2nd set of df210 got it as a present but selling it ;]
Old Dec 14, 2007 | 09:39 AM
euro argh's Avatar
i had that problem too
it turns out skunk2 had a bad batch of rear coilovers where they are way too short
luckily, they are not too far from me so i was able to go over there and get the correct size ones
o8 ENVII 8o
Nov 30, 2015 04:23 PM
trev0006
Aug 3, 2008 03:06 PM
BackToStock
Oct 23, 2007 02:17 PM
injunjoe
Nov 4, 2002 05:48 AM
