Enkei EDR9 fitment
Enkei EDR9 fitment
First and foremost my apologies on this thread, but I suck at using the search option, which I did try first. My question is straight forward...With my budget allowing me no more than $160 a wheel, will I have fitment issues with either the Enkei EDR9 17" 45mm offset running 235/45/17 or with the Enkei Imola 18" 38mm offset running 235/40/18's. I have a Koni/Nuespeed (mid-perch) set-up on a 2004 TSX. Like I said, I'm sure the offset question has been addressed but I'm limited on time to purchase. Thank you all in advance.
For the 18" Imolas you'll be marginal if the wheel width is 8" and you'd be fine at 7.5". Rubbing appears to start once offset is below +42 on an 8" wheel for a 235 tire - depends on your camber too.
I'm 18x8+40 (235 tire) and haven't rubbed even with a full load but I'm only lowered .75" - a small number of folks say they do rub at that fitment though.
WFC (08-13-2011)
WFC (08-13-2011)
MrHeeltoe
79
10-14-2015 08:47 AM
adreano17
09-29-2015 08:48 AM
nuldabz
09-03-2015 05:49 PM
