DBA or Brembo Rotors
Hi All,
I read lot of threads reg the after market rotors and decided to get either DBA ( most probably i will get these) or Brembo blanks ..
I have Hawk HPS Pads..
The other options i have considered are r1concepts , PowerStop Cryo and EBC..
The primary reason i am palnning to go for DBA is because of the reputation. ( also i would like to try thr slotted and drilled ones..)
Has any one of you have these rotors ??
Any inputs will be of great help..
Thanks a lot
Mars
Thanks a lot
Mars
Former Sponsor
Don't forget to look at Racingbrake. May favorite ![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
I have a supplier that distributes DBA. They look to be a good high quality part. Not sure if they are carrying rear rotors yet which is something to consider if matching the rears is important to you.
Brembos are basically stock rotors. If you still have material left on your stock rotors, keep them in favor of going to brembo. You won't gain anything.
9/10 rotors are all the same with different machining and costing processes done to them. Look for a good high quality and engineered rotor like Racngbrake or DBA over the rest.
Marcus
Marcus
Driver/Detailer
My advice with DBA (I'm from Australia, where DBA is based), is to go for the slotted 4000 series. Skip the cross drilled as those are for street use only.
The difference between the street, 4000 and 5000 series is that the street are your OEM replacements, the 4000 gets heat treatment, kangaroo paw pattern vents and the temperature indicators. The 5000 gets all the features of the 4000, plus is a 2-piece design with an aluminium rotor hat.
Also for the rears I think I had to do a bit of research. If I remember correctly, DBA doesn't offer rear rotors for the TSX per se, but they do for both the Euro-R and the USDM 03+ Accord. The part numbers were the same for the Accord and Euro-R rears, and since all these cars have the same rear brakes as the TSX anyway, I assumed the USDM accord rear rotors would fit and they did (same diamater and thickness, etc.)
Driver/Detailer
Hi All,
Thanks a lot for your inputs..I have got the HAWK HPS Brake pads and ordered the DBA 4000 Series (Slotted and Drilled) rotors.
Now i might need to get a mechanic to put these on.. As far as brake pads are concerned i guess i can do it my self but the rotors i am not sure..
Also they need the proper bedding..
I tried calling places like NTB and they said they won't do it if i bring the rotors and pads (i guess they want me to use their stock rotors or pads)..
Any idea how much a shop will charge for installing these ??
Really appreciate your suggestions..
Mars
Mars
Driver/Detailer
Hi All,
Mars
Mars
Hi all,
I am planning to install the Rotors myself and will post the pics once it is done..
My Front door actuator failed..It seems i need to install it as well..
Will post the pics once it is done..
Mars
Mars
ridiculously good looking
what would you guys recommend for someone who wanted blank (standard) rotors? DBA or Brembo? RacingBrake doesnt seem to have any non-slotted rotors.
Was glad to find your post re DBA rotors.
Appreciate any update you can share pertaining to
mileage,warpage &/or cracks etc...
Thanks.
Thanks.
Hi All,
Mars
Mars
