CL/TL to TSX wheel compatibility..
Old 05-26-2009 | 05:42 PM
150shot's Avatar
Do all these stock rims interchange with one another in terms of fitment? I think the Type S wheels are a bit wider, but just wondering as I'm looking into a spare set from a CL or TL.
Old 05-27-2009 | 09:15 AM
sortudo7's Avatar
Site Lurker, Rare poster
Depends on the years, overall I'd say you'd be fine. I had 08 TL-S rims on my car which were 17x8 +45 with 235/45 tires (or else 235/40, I forgot, whatever OEM tires are on the TL-S). I was at stock height at the time but had no issues whatsoever.
As long as the rims are 5x114.3 with an offset of +45 up you should be fine. Maybe even a lower offset. It all depends on your drop, rim size and offset and tire size. There are ppl dropped running 19's and 18's without any issues besides some negative camber. If you run 17's with decent sized tires and a mild drop you should be fine. I am with no finger gap on 18x7.5 +42 on 235/40 with no rubbing at all running mild neg rear camber, front is in spec.
divac
08-29-2018 10:13 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
TSX 09
09-06-2015 01:07 PM
nuldabz
09-03-2015 05:49 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: CL/TL to TSX wheel compatibility..
