camber question
camber question
i tried searching but i got a little confused...
so today i installed my tanabe nf210's and i was looking for the ingalls camber kit. i know its about 75$ per side. my question is, if i order the camber kit for both sides, does it fix my toe setting when i do my alignment? or do i need to order 4 pieces and use 2 for camber and 2 for toe? or what?
and also, would i need to purchase anything for front alignment?
thanks
thanks
Let me help you!
You don't need anything for your front.
Camber kits are designed to fix your camber...not your toe. However, there are two camber kits...SPC and ingall. Ingall's camber kit gives you some toe adjustment if you need it in addition to the stock toe adjustment.
ok thank you
so i just need the 2pcs.
i was just wondering because i see people with the camber kit and then it looks like they also use the same pieces for toe.
like this:
https://acurazine.com/forums/showthr...t=camber+links
it was just confusing me
like this:
I was also wondering, the ingalls camber kit adjusts the camber, and adjusts the toe, for a good adjustment, should the rear tires toe be negative, meaning the top of the tire looks pointed inwards? or should it look stock, and straight up? i see people with camber kits, and have their toe at negative, does that fix the tire wear?
Let me help you!
Former Sponsor
The Ingalls kit has 2 arms per side. One for camber and one for toe.
https://acurazine.com/forums/sponsored-sales-group-buys-10/ingalls-camber-kit-sale-acura-cl-rl-tl-tsx-352963/
There are pics in that link of the rear setup with 2 arms.
Driver/Detailer
Stick to stock unless your car sees tracktime often.
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
navtool.com
09-25-2015 05:15 PM
