Bubble in my sidewall
Old Jul 11, 2005 | 08:10 PM
fdl's Avatar
fdl
My stock tire has a 2 inch bubble in the sidewall. I have about 34,000km on these tires.
- Can I get this replaced under warranty? I am positive that I did not hit anything. The tire must be defective
- How dangerous is it to be driving like this? I'm worried about a blow out.
Old Jul 11, 2005 | 08:31 PM
CCColtsicehockey's Avatar
doesnt sound like a good thing
Old Jul 11, 2005 | 08:50 PM
curls's Avatar
Someone stole "My Garage"
not a good thing at all. Go to any Michelin dealer, or your Acura dealer, and tell them. It should be warrantied for sure.
~Eric
Old Jul 11, 2005 | 09:00 PM
fdl's Avatar
fdl
~Eric
Well, I sure hope so.
Old Jul 11, 2005 | 09:01 PM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
If there is any damage to the liner of the tire wear the bubble is you stand zero chance of getting it replaced under waranty. If there is not damage to the liner you stand a very slim chance. Road hazard type waranties on OE tires never go smoothly for anyone involved.
What ever the case may be get it taken care of sooner then later, be it a seperation or an impact break its not good!
Old Jul 11, 2005 | 09:07 PM
fdl's Avatar
fdl
The tire is completely clean over the bubble. Not a mark or scuff on it. ANd i am positive i didnt hit it. But i doubt they will believe me.
Old Jul 11, 2005 | 09:18 PM
Dan Martin's Avatar
Photography Nerd
Good luck with your dealer. I didn't get anywhere when I tried to get them to replace mine. They're farking expensive too. I think I paid somewhere close to $270 mounted and balanced.
Old Jul 11, 2005 | 09:32 PM
NJtsx's Avatar
Automobile Aficionado
wow very rare for Michelins.
Old Jul 11, 2005 | 09:42 PM
gsclifton's Avatar
ABP TSX
I would demand a chicane be installed on every road so your speed WILL be slow enough to be safe
Old Jul 11, 2005 | 10:20 PM
SDCGTSX's Avatar
Mine got fat bubbles on my CL. I think over pressuring the tires coupled with a pot hole tend to do it. I got a fatty and I had my tire pressure at 36 vs. recommend 32. I reduced the pressure and no new ones grew. Depends on the size of it I guess on how madly it needs to be changed.
Old Jul 11, 2005 | 10:51 PM
Alin10123's Avatar
Yea, i dont think that the normal stock tires will come with a warranty that will cover bubbling. On the other hand, if you have a road hazard protection when you got new tires... that would definately cover it.
Old Jul 12, 2005 | 09:25 AM
kurt_bradley's Avatar
And if they don't do that, refuse to drive.
Old Jul 12, 2005 | 09:43 AM
dom's Avatar
dom
Sounds like a great opportunity to get some decent tires You can get FUZION™ ZRI for ~ $160 each.
Good luck with the dealer.
Old Jul 12, 2005 | 09:46 AM
Nighthawk04's Avatar
That bubble will cause that wheel/tire assembly to become *less* balanced so you might notice some new vibrations while driving at high speeds (70mph+).
Old Jul 12, 2005 | 09:53 AM
iTimmy's Avatar
dɐɹɔ ǝɥʇ ʇɐɥʍ
The liner is on the inside of the tire, if there is a break where the damage is its known as an impact break and will not be covered under waranty- its quite common.
Old Jul 12, 2005 | 09:57 AM
Dan Martin's Avatar
Photography Nerd
You shouldn't be doing any high speed driving with a bubble in the sidewall. As exciting as high speed blowouts are, I'd like to get my thrills elsewhere.
Old Jul 12, 2005 | 10:06 AM
leftride's Avatar
i want to ride my bicycle
i just put a set of falken 512's on for about $375 mounted and balanced.
Old Jul 12, 2005 | 10:11 AM
mg7726's Avatar
She said: it's GINORMOUS!
$160?!?!?! that's a rip off! they sell for $88/tire at Tirerack.com.
Old Jul 12, 2005 | 10:16 AM
leftride's Avatar
dont forget.....
Old Jul 12, 2005 | 10:30 AM
TSXTuner's Avatar
A bubble is broken cords. Change the tire immediately.
I haven't cut open my michelin to verify yet. This tire may have the
new process that bodyply does not wrap around the bead and turnup
outside.
Their new process truncates the cord ends, sandwiched between two
bead halves.
I've heard alot of talk about this failure mode in michelins.
Inspect your rims close, particularly inside, is there any bending
for flat spot on the rim at the bubble location.
Almost no chance they'll warranty it, they just say you hit something.
Time to get new tires. Pirelli Pzero Nero was a step up in handling and
wet traction for me, made in America, Georgia.
Fuzion for cost effective high perfomance top wet traction and
light snow capability and will last reasonably well for this capability.
Toyo has good rep. I don't want to leave out Falken and Yokohama, never used them myself, just don't know. The Yokohama facility in Virginia is not
world class, it probably depends if you get some out of Japan or Virginia.
If your going for the ultimate highway tourer, cost not issue, Bridgestone
Turanza LSV.
For cheap all round the new Kuhmo all season is doing real well on the family van, good wet traction, quiet.
They'll 'bout all get the job done, but there are some bad ones. Had to take
off a set of Summitomo first day, like on ice in the rain.
Powered by Honda's Avatar
Originally Posted by virus7
dont forget.....
Dam!!!!
Now make up and :gheyhug:
Old Jul 12, 2005 | 10:32 AM
peterjedi's Avatar
A stock tire is $185-$200 cost. Installation and insurance is extra $20-$40 dollars (US prices).
It seems the aftermarket tires are cheaper then stock. Why?
fdl: The bubble is not covered. I don't think even road hazzard covers a bubble in a tire. Check with a major tire resaler, like NTB.
Old Jul 12, 2005 | 10:33 AM
dom's Avatar
dom
dont forget.....
Considering $88 US = ~ $110 CAD these days $160 is a rip off
Old Jul 12, 2005 | 10:40 AM
CGTSX2004's Avatar
Actually, America's Tire's road hazard warranty covered the two bubbles that developed on two different Kuhmo tires that I had on my old Integra.
Old Jul 12, 2005 | 10:51 AM
fdl's Avatar
fdl
Guys, i just need this fixed fast. I need to go to work. Getting it done at the dealership. Its not covered under warranty and costing me $240 CDN.
Old Jul 12, 2005 | 10:52 AM
CGTSX2004's Avatar
Ouch...that sucks...
Old Jul 12, 2005 | 10:57 AM
Dan Martin's Avatar
Photography Nerd
Well if it's any consolation, that's less than I paid.
Old Jul 12, 2005 | 10:58 AM
fdl's Avatar
fdl
what was wrong with yours?
Old Jul 12, 2005 | 11:25 AM
Dan Martin's Avatar
Photography Nerd
Same deal, bubbled sidewall.
Old Jul 12, 2005 | 11:45 AM
dom's Avatar
dom
IMO you were better off buying 4 new tires. And how much more time could it have taken?
Now in another 34K you'll need 3 more new tires.
Of course at your pace that may take 2 years so maybe someone like mysef or manusauce would have benifitted from 4 new tires.
Old Jul 12, 2005 | 12:12 PM
fdl's Avatar
fdl
dom, i hear ya. But i didnt have time to research tires and if i get summer tires then i would need to buy winters as well.
The news gets worse, apparently i need to do my alignment as well. $129 + tax
Old Jul 12, 2005 | 12:38 PM
peterjedi's Avatar
I need to make a correction. If the bubble has a bulge or is warped, then you are not covered. If you just have a bubble without any bulge or warping, then this is a defective tire.
Old Jul 12, 2005 | 12:49 PM
fdl's Avatar
fdl
how can you have a bubble without a bulge?
THe dealer told me that Acura doesnt warranty tires period. They stopped in 2003. (i'm not sure if this is Canada only )
Old Jul 12, 2005 | 01:02 PM
Dan Martin's Avatar
Photography Nerd
I got the exact same answer from my dealer and from the tire shop that ended up doing the replacement for me. The new tire came with a warranty though.
Old Jul 12, 2005 | 01:03 PM
dom's Avatar
dom
Too busy posting BJ threads
Old Jul 12, 2005 | 01:11 PM
fdl's Avatar
fdl
Old Jul 12, 2005 | 01:16 PM
dom's Avatar
dom
BTW - I like how you only enter the TSX section when you need help.
Old Jul 12, 2005 | 01:35 PM
fdl's Avatar
fdl
Old Jul 12, 2005 | 01:41 PM
peterjedi's Avatar
Structual damage to the tire is caused by road hazard. If you just have a bubble with no structual damage, then you have a defective tire. Acura might not warrantee the tire, but Michellin might.
I had the bubble problem too. I paid $242 to replace it. In my city, Boston, there is a pot hole law, that I might be able to get my money back within 30 days of the report. Check with your city hall. See if there are any kind of laws that protect you, then find the bigest pot hole in the city. :-)
Old Jul 12, 2005 | 02:34 PM
fdl's Avatar
fdl
There was no damage at all, just a bubble. Acura definately wouldnt cover it. I called a Michelin dealer and they said they woudlnt touch an OEM tire. So I was SOL.
Plus the alignment was off which is more evidence that i hit something.
