Brake rotors
Old 08-02-2003 | 10:35 AM
tsx-fl's Avatar
Brake rotors
Thinking of switching to EBC Sport Grooved Sport Brake Rotors. I am trying to improve the brakes which I find unsatisfactory.
Old 08-02-2003 | 12:50 PM
ebcheon's Avatar
so do it...
Old 08-02-2003 | 01:36 PM
tsx-fl's Avatar
Wondering if it's worth the trouble?
Old 08-02-2003 | 11:18 PM
DEVO's Avatar
hmmm... don't
i have the EBC sport grooved brakes rotors... i like their pads (green stuff) but the rotors feel like they are warped when braking (they are not warped but the slots give that sensation)... also, the protective coating last about a half of winter, then everything starts to rust.
overall braking has improved but I'm betting that most of my braking gains come from just switching to green stuff pads.
Old 08-03-2003 | 09:53 AM
tsx-fl's Avatar
Originally posted by DEVO
hmmm... don't
Thanks man! I'll get the pads. Super.
Old 08-04-2003 | 04:08 PM
kurt_bradley's Avatar
A recommendation
If you wanna get a rotor swap done to help out your braking too, the Spoon ones are great. Had them on my RSX. They're the same rotors on the TSX as the RSX-S. They're in no way cheap, but they're better ventilated (cross-drilled), they're better for long term use, and they're over 3 lbs lighter for each rotor than the stock ones.
Old 08-04-2003 | 09:06 PM
tsx-fl's Avatar
Re: A recommendation
I am unhappy with stock configuration. When braking lightly I feel some sort of vibration through the steering wheel. What's the impact of lighter rotors? Thanks.
Old 08-05-2003 | 02:27 AM
DEVO's Avatar
Re: Re: A recommendation
if you are feeling a vibration already it could mean 2 things... one you have already warped your rotors... 2, you have an unbalanced tire.
unless what you are feeling is the anti lock kicking in. does this happen all the time?
I warped my GS-R rotors within 4000 miles of owning it... was a bit pissed because I didn't think I was braking that hard... had them milled and the problem never occured again.
you run the risk of warping the rotors if you decided to lighten them by buying thinner rotors, so be careful.
Old 08-06-2003 | 02:21 PM
The Spoon ones are no thinner, they just have a lighter weight because of the materials used. Their intent is for endurance racing (just as any Spoon parts are), so wear should be no issue. As for your vibration, just take it to your dealer. It could be a "warranty-related" issue. If not, you could at least find out what's actually causing your vibration.
Old 08-06-2003 | 08:01 PM
tsx-fl's Avatar
I can not visually see the shacking. It's more like a grinding vibration of the steering wheel coming through my hands. A subtle vibration felt a low speeds when breaking. Car stopping straight and without hesitation.
Stopping in traffic I am pretty gentle with my brakes but with the car having such nice acceleration at higher speeds I have used them aggressively for slower traffic when speeding in the 100 to 115 mph range.
I am definitely interested in the Spoon rotors. I get the impression the stock brake configuration is weak for the kind of driving this car allows.
Old 08-07-2003 | 10:23 AM
DEVO's Avatar
yeah... then you warped them... at high speeds (100 plus), you will generate more heat and you will warp the rotors quicker.
Old 08-07-2003 | 10:42 AM
I agree with DEVO, you warped them. The stock ones really can't handle higher speed, heavier braking. It does produce much more heat than they should take on a normal basis. The Spoons definately handle more heat for more life. I can assure you of that. I've loved the results I had on my RSX with them. Smoother, shorter braking is great, but then you throw in the lighter unsprung weight.
Old 08-08-2003 | 07:17 AM
tsx-fl's Avatar
I am not sure what you means by "you throw in unsprung weight"?
Old 08-09-2003 | 10:29 AM
Unsprung weight, as in wheels & tires and brakes. These are items that aren't attatched to your car that has to be affected by your suspension. The lighter your unsprung weight, the better your handling can be.
Old 08-09-2003 | 10:58 AM
tsx-fl's Avatar
Understood. I do not like to modify just to modify but replacing the stock tires for better grip and getting better rotors seems like a plus here. Do I need to change all four rotors or only the front ones? Thanks.
Old 08-09-2003 | 08:34 PM
You can do just the fronts if you want to (at least do the fronts to get any real benefit). To do the whole set is going to make a difference overall, of course. Your stopping distances are going to be heavily shortened and your brakes will be much less subject to wear. They're much stronger in material than the stockers.
Old 08-13-2003 | 07:20 PM
tsx-fl's Avatar
There is something weird about the rear wheels. The rotors look very small. Some how the look is not just right. I am wondering if it’s possible to install larger rotors and calipers.
Old 08-14-2003 | 03:57 PM
Yes, it can be done. I wouldn't say that the rears are small, but they are a little different in size (by 2") than the fronts.
Old 08-14-2003 | 04:22 PM
Iceman's Avatar
The car is so front-heavy that the rears don't need to be very big.
Old 08-16-2003 | 09:29 AM
Correct.
Old 08-16-2003 | 11:01 AM
tsx-fl's Avatar
Understood and I will change front rotors with Spoons for better braking but esthetically the rear wheels look funny because of size of rotors. From a purely visual perspective there should be some kind of improvement done in my opinion!
Old 08-16-2003 | 11:42 AM
I agree that the rears look out of place on the stock setup. The Spoons look much better all around. Especially since they're cross-drilled.
Old 09-15-2003 | 07:16 PM
tsx-fl's Avatar
As anybody changed their rotors on the TSX?
Old 09-16-2003 | 11:44 AM
RogerPodacter's Avatar
So, do you like...stuff?
I just had mine resurfaced at 10K miles
Old 09-16-2003 | 12:16 PM
tsx-fl's Avatar
What was the problem?
Old 09-16-2003 | 01:29 PM
LurchRSX's Avatar
This gives me an idea.....what about putting the brembo "TL" upgrades on the TSX
Old 09-16-2003 | 01:30 PM
LurchRSX's Avatar
Old 09-16-2003 | 02:34 PM
tsx-fl's Avatar
Not available for TSX.
Old 09-16-2003 | 06:33 PM
tsx-fl's Avatar
What about AEM Four Piston Caliper Big Rotor Brake Kit, front and rear? They make them for the RSX-S. Should fit the TSX???Anybody has experience with them?
Old 09-16-2003 | 06:36 PM
ClutchPerformer's Avatar
That's a hell of an idea!! The bolt pattern is the same. All we have to do is check wheel clearance. Hmmmmm....
Old 09-16-2003 | 06:39 PM
tsx-fl's Avatar
Let us know if that would work?
Old 09-16-2003 | 09:04 PM
I dont know, they just warped. i dont drive very hard.
Old 09-17-2003 | 06:47 AM
tsx-fl's Avatar
I have the same problem. I don't like my brakes. Trying to figure out what to replace them with.
Old 09-17-2003 | 10:12 PM
GBalt's Avatar
There are some pretty good looking brake products for the TSX here at www.brakeworld.com. The slotted rotors seem like a reasonable upgrade, but I'm really eyeing the big brake kit.
Old 09-18-2003 | 12:13 PM
captainjack's Avatar
Über Geek
I just poked around to get Spoon rotor prices.
Whoa. They start at ~$235 PER ROTOR.
I'll have to save up my babysitting money for a WHILE.
Old 09-18-2003 | 11:30 PM
dnl2ba's Avatar
Okay, I read through the thread and I still don't know what I need to get to upgrade my brakes. (Not a car enthusiast-- never cared much about my previous car, and I just got the TSX 5 weeks ago.) I'm not exactly racing at the track, so it's not like I need super-pro brakes; I'm just alarmed by the long stop distances even during stop-and-go on my commute and want something that feels more safe. Would I need to get rotors and pads and calipers and lines? Whatever I need, what can I expect to pay in total (for the materials and labor) if I have them professionally installed?
I'm guessing my brakes are not something I want to dick around with if I don't really know what I'm doing.
Old 09-19-2003 | 09:00 PM
DEVO's Avatar
dnl2ba, just try upgrading the pads... which is a very cheap solution. try the green stuff, they have done the trick with my car.
Old 09-20-2003 | 12:29 AM
GBalt's Avatar
how much has your Tsx's braking performance improved from using the green pads (EBC?). Also, how much were the pads and from where did you buy them?
Old 09-20-2003 | 01:41 AM
Alin10123's Avatar
Has anyone tried the big brake upgrade kit on "brakeworld.com?" Can you tell us about it?
I'm interested in this kit too.
thanks
Old 09-20-2003 | 03:34 AM
DEVO's Avatar
Don't own a TSX, I used the green stuff (EBC) on my Acura GS-R which I thought had terrible stopping power. With the pads alone I noticed a huge difference is stopping distance. When I upgraded my rotors (EBC rotors), I noticed no difference except for the annoying feeling of the vibration of the slots on the rotors. So I thought the rotors were a waste of money while the pads seemed to have been good enough.
I bought the the rotors and pads at www.tirerack.com.
Quick Reply: Brake rotors
