Anybody have Tein H-tech springs in their TSX?
Do a search.
But I did have these at one point, soooooo here are my answers.
Ride comfort is comparable if not similar to stock.
As far as ride height, very pleasing to the eye. If you are going for the subtle look. Not to low but, a tad bit lower than the A-spec kit.
Pros: They drastically improve cornering, and looks. They are afordable, they work with OEM shocks (still recommend aftermarket ones) and ride doesn't diminish too much and athey won't throw your alignment off too much.
Cons: If you stay with OEM shocks they will eventually fail. Also, IF for some reason you want the car lower you have to purchase different springs and or coil-overs.
Hope that helps. BTW here's a pic when I had them....
Installed them on my car probably 3-4 months ago, I love them. I wanted to drop my car, but I didn't want it too low, so I went with the H-Techs. The handling is much improved and the ride quality is better than stock. Here are a couple of pics:
With 17" HFPs
WIth 18" A-Specs
With 17" HFPs
WIth 18" A-Specs
Thanks guys! I coud'nt decide coz I thought it will not make a big defference as it only lowered 1.1" front & .7" rear. I didnt now that It will look realy nice. I will definitly get one!
With 17" HFPs
WIth 18" A-Specs
With 17" HFPs
WIth 18" A-Specs
After reading this thread I too will buy the H tech springs. Which dampers would everyone recommend? Keep in mind I would like something that will not compromise the ride quality of the car. I don't want a daily driver that feels every bump in the road.
I don't have this setup, I have BuddyClub RSD. When switching car w/ my buddy (also had a fully mod TSX, the one behind me in da avatar) w/ the above setup, I always enjoy how smooth the car ride and absorbing bumps pretty well on road too. The only downside is no matter how hard the damper setting is, it still very soft for fast tracking.
Koni Yellow + TEIN S/H Tech spring would be good.
I have the H-Tech's and am running Tokico HP's ("Blues"). They are about $80-$100 per corner and made a GREAT difference in the comfort, handling, and feel of the suspension vs. having the stock shocks on there for a year. I'm very glad I made the switch to performance shocks -- much less bouncy and worth every penny.
I would rather you save up then do it right all @ once, at least you can keep a PERFECT condition stock suspension, and do not need to pay installation TWICE (avg. $150 here).
Thanks in advance
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
