Alignment specs after A-spec suspension
My A-spec suspension is fully settled, so I brought it in today for an alignment. One thing this shows is that the rear camber is adjustable, to a degree. The amount of rear camber is fixed, be it can be shifted from one side to the other by loosening the bolts that hold the carriage and moving the carriage to one side or the other. My car ended up at -1.7 left and right, which is not enough (for me, anyway) to warrant a camber kit. It is .2 degrees out of spec. Everything else lined up well within spec. I only drove it a couple miles so far; I'll give more feedback after I get a chance to push it a little.
Front Caster (spec range 2.47 to 3.97)
Before: L: 2.5_____After: L: 2.5
______R: 2.7_____R: 2.7
Front Camber (spec range -0.75 to 0.75)
Before L: 0.02__________After: L: 0.02
______R: 0____________R: 0.0
Front Toe (spec range -1.00mm to 1.00mm)
Before: L: -0.4mm_________After: L: 0.0mm
______R: -1.1mm__________R: 0.0mm
Rear Camber (spec range -1.5 to -0.5)
Before L: -1.4____________After: L: -1.7
______R: -2.0_____________R: -1.7
Rear Toe (spec range 0.00mm to 2.00mm)
Before L: 0.1mm_________After: L: 0.9mm
______R: 0.5mm__________R 0.8mm
Rear Thrust Angle
Before 0.02_____________After: 0.01
Rear Thrust Angle
not terrible, at least they could even it out so the car with drive straight. personally I think its worth it to get the camber kit if you're already dropping a bunch of $$ on the spring/shock
I'm going to keep an eye on rear innner tire wear, but unless it wears badly, I don't see the point in getting one, as the handling is right where I want it. My plan is to use the el crappo stockies through the winter anyway, and get some summer tires or better all seasons next year, maybe Pilot A/S.
That being said, any aftermarket setup is absolutely going to require a rear camber kit, with the possible exception of the Comptech springs, which are rated at a 1" drop. Prokit, Nuespeed, etc are all at least 1.5" drop, which has got to put the rear camber up into the -2.0 or more range........
With that rear camber spec, it will easily go out of spec with a full tank of gas and two passengers in the back...
My extra .2 degrees is not all that much worse than stock.
I'm dumping the stock rubber next spring, so I really don't care if it wears unevenly, but I do not think it will. If I am wrong about the tire wear, surely I will be able to see it by next March, at which point I would add a camber kit.
Originally Posted by LannyM
Actually, the car felt fine before the alignment; the out of whack rear camber does not affect tracking.
That is not entirely true- thrust line CAN be out enough to cause a vehicle to dog track. This is more typical with toe, however, it can happen when cross camber is an issue.
Also what alignment rack was used??? it still measures toe in mm, was it powered by a hamster in a wheel chasing a cheeto?
Well, let me rephrase then. MY out of whack rear camber had no affect on tracking. I put around 400 miles on the car and the car didn't drift left or right, could roll miles on straight highways without touching the wheel. Coupled with improved handling, I really felt the settings were pretty close to factory spec, and they were.
It was done at the dealer, just like the install. I called a couple of shops that have "state-of-the-art" alignment machines, but when I asked about adjusting the rear camber on the TSX, they told me there was no way they could change it. The guy at the dealer, however, knew the trick about moving the carriage. So while I may have had a hamster powering the machine, at least I didn't have one running it .
Originally Posted by JTso
With that rear camber spec, it will easily go out of spec with a full tank of gas and two passengers in the back... Imagine how the tires will wear after a long trip.
In my experience with lowering cars (all 5 of the cars I've ever owned have been lowered) I have found minor additional inner tire wear with additional negative camber. The tires still last a good 90% of their typical life.
OTOH, excessive toe in or toe out will chew up a set of brand new tires in literally a few thousand miles. I went through a set of front tires in only 5,000 miles b/c the front toe was out of alignment.
Originally Posted by joerockt
I got the Comptech springs along with the camber kit. I think this falls under the catagory of better safe then sorry.
Originally Posted by AlterZgo
I think its a myth that excessive negative camber causes significantly more tire wear.
Originally Posted by Newplay1
Do you have any pics? I just ordered mines monday.... Comptech springs+SPC rear camber kit and progress lower rear sway bar.
hey LannyM, how did you have the alignment shop adjust the rear cambers to even out at -1.7 degrees both sides? I took my car to the alignment shop @ Firestone today and my rear left is it -1.4 while rear right is -2.3 degrees. They told me it wouldn't be possible to adjust the rear. I'm hoping that before I get my camber kit, they can at least even out both sides to -1.8 or -1.9 degrees, please advise.
-K
-K
-K
-K
Thanks guys, hopefully Firestone will know how to adjust it through moving the carriage before I get my camber kit.
Virtualbong, all cars have problems, and believe me, the joy you will get out of your TSX will slam on the camber issue like a giant stepping on a lil worm. The Firestone technician actually commented on how sweet my car looks doing the alignment
And I've already decided that I'm going to get the Rear Ingalls Camber Kit since the install is pretty simple. Now I have to decide on used A-Spec Manual Kit (I have auto) for $400 or brand new Eibach Pro-System Kit for $500
Originally Posted by bigwilliestyle
400 bucks. Where's that from?
Interesting... didn't realize he was selling it. He doesn't like it?
I haven't changed my opinion of it, for the money, it really gives a ton of benefits with really no downside; but it's not as stiff as I would like, and my wife's Ody is get 99% of the baby toting duties, so I can definitely go stiffer.....
Originally Posted by virtualbong
This whole deal is confusing the hell out of me. I feel confident about what I want one day and then I read a thread like this and question myself again. Damn it.
Just jump into it. I know you've done your research. After a while, you just have to make a decision. Of course, you could end up like I did with my last car and bought 3 sets of different shocks and 3 different sets of different springs and kept messing around with the various combinations. I got pretty good at uninstalling and installing my suspension. It was a pricey experience, but I learned a lot in the process. It felt great when I finally found the perfect mix of handling and ride quality.
I don't think you can go wrong w/ Lanny's A-spec suspension or the Eibach Pro-System. Of course, no one here has experience w/ the Pro-System yet. But, given that Eibach is a very reputable German manufacturer, I'm sure it is fine.
Originally Posted by EURORTSX
i installed the a-spec a few weeks ago...but i was never told to get an alignment after awhile...do you guys think i should?
VB,
I did jump into it, I made the first step and that was to purchase the Rear Ingalls Camber Kit from Ultrarev.com. I was never going to get this if I were to just get A-Spec, so now I'm leaning towards the Eibach Pro-System Kit because it has the drop I like. Plus, now that they have matched a set of struts to their springs, I am confident that this would be a great combination. I understand though that this doesn't come with any type of adjustability, but that's not what I'm looking for in my suspension setup.
So LannyM, what do you think? Do you see any noticeable/abnormal wear with the A-Spec?
Since I installed the kit, there have been multiple reports of both out of spec rear camber and some uneven tire wear even with people who are on stock suspension.
I'm installing Tein Flex this weekend, and I do have the Ingalls camber kit on order, because with the Flex drop I'll be over -2.0 for sure, and I'm also switching to soft rubber (Yokie ES100s) so I'm going to dial it back to around -1.3 or so.
Me too. I was convinced that the A-spec was the "safest" bet since it's the official Acura upgrade and that I wouldn't have to mess around with camber adjustments or anything, but this thread makes me wonder.
The other thing that's tempting me is Neuspeed Konis with Neuspeed sport springs. But I'm nervous about not going with a "matched" system like the A-spec or Eibach Prosystem.
Originally Posted by rmpage
lol
I also just purchased the Neuspeed Konis this morning for $576.99 shipped on Ebay!
Well they're both made by Neuspeed, though I don't know if they were made for each other. This is what I'm going with after researching and figuring out what I would like. I know that the Neuspeed Sport Springs drop it 1.5"F+1"R and that would balance out my car perfectly since I measured my front wheel gap to be 2.5" and my rear wheel gap to be 1.75"-2".
Did you get some rims too or are you going with 17" ES100 on stock rims?
Just an FYI. People who have installed the Neuspeed Springs were getting more than 1.5" F and 1" R drop. I think JTso may have gotten something like 1.9" or so drop up front. So he had to lower the rear spring perch to get a more even front to rear drop.
This is what it looks like after the drop with Neuspeed/Koni combo.
Lanny,
But, having said that, I'm somewhat concerned about putting a 225 on a 7" rim. It falls within the manufacturer's spec (range is 7"-8.5"), but I've always liked the way a wider rim spreads the tire out, and disliked the "donut" effect that a wide tire has on a narrow rim, so I'm still kinda up in the air. The thing is, the sidewall on the ES100 is so stiff that it may not look bad, but it might be pulling the tread off the road, crowning little in the middle, and that's not good either.
I've already got two people interested in the Type S rims, (they're due on Monday) so I may look to go wider......I'm going to mount one up and see how it goes.
The Neuspeed actually drops about 1.75" to 1.80" F & 1.0" R. I lowered the rear by another 0.5" using the Koni perch adjustment.
One question to prepare for the install. I'll probably need to lower the rear .5" as well. From what I've read, please let me know if this is what I have to do for my suspension install.
1. Uninstall the stock suspension
2. For the rear shocks, adjust the perch to 0.5" lower (how many rotations is this or will the instructions tell me?)
3. Assemble the Neuspeed Sports springs with the Neuspeed Koni Yellows and reuse the top mount from the stock suspension
4. Install the new suspension setup to the car.
Sound good? Anything else I need to do other than the steps I mentioned above?
You will also need to enlarge the top hole on the stock dust boot and use new included Koni mounting hardware. The height is adjusted by relocating a snap ring on the shock body, not by rotation like a coilover.
