235/40-18's on a 7.5" wide wheel
Hey hows it goin!
I got a set of Volk Racing CE28N 18 X 7.5 Offset +50 in Mercury Silver on order from Japan, and I was wondering if I could fit 235/40-18 Toyo Proxes T1-S on them? From Toyo's website, the recommended wheel width range is 8"-9.5", but I prefer this size over the 225/40/-18 due to it better matching the overall diameter.
Any input would be greatly appreciated!
Thanx!
Thanx!
They will be perfect. Last night I installed my new wheels (ASA AR1s 18x7.5 +48 with 235/40 R18 tires). They fit perfect! No rubbing at all and they don't stick out past the fender lip. 235s are the only way to go!!!
I'm the Firestarter
Originally Posted by acuratsx03
now lets see some pictures
It's not dropped.
I'm the Firestarter
Originally Posted by Dan Martin
Man I don't know how that isn't dropped. It looks at least an inch lower than stock. Looks great though!
Hey Belzebutt,
I know you said you have no rubbing issues, but that's because your car isn't lowered. Are the tires sitting underneath the fender? Or is the tire completely inside the wheel well?
I'm the Firestarter
Design By Force
Originally Posted by InspireSiR
Hey Belzebutt,
I have been looking at a set of rubber for them but also have been going back in forth between 225's and 235's. I'd take the 235's, but I also am going to put the a-spec susp. on there. think it'll fit?
...it's those 235's and the rim design that make the gap between the wheel well look so damn small... i love it.
Design By Force
Does anyone have any suggestions on tires as well?
I want summer tires, but i am out here in seattle, lotsa rain but snow happens maybe one or two days a year. Can i still go with summer tires, or how much am i sacrificing going for some A/S?
Possible A/S:
Toyo Proxes 4
Pirelli PZero Nero M/S
Yokohama AVS dB S2
Possible Summer:
Toyo Prozes T1-S
BFGoodrich g-Force T/A KD
Yokohama AVS ES100
Nitto NT 555 XP
I know these tires vary quite a bit in price, but are you really getting what you pay for?
Thanks in advance, i'm a nooB on tires...
Possible A/S:
Toyo Proxes 4
Yokohama AVS dB S2
Possible Summer:
Toyo Prozes T1-S
Yokohama AVS ES100
Nitto NT 555 XP
Photography Nerd
Possible A/S:
Toyo Proxes 4
Yokohama AVS dB S2
Possible Summer:
Toyo Prozes T1-S
Yokohama AVS ES100
Nitto NT 555 XP
Possible A/S:
Toyo Proxes 4
Yokohama AVS dB S2
Possible Summer:
Toyo Prozes T1-S
Yokohama AVS ES100
Nitto NT 555 XP
The two days a year that you get snow in Seattle will be completely undrivable on summer tires but if that's not a big concern then I'd recommend summers for sure. The Toyo T1-S is soon to be replaced by the T1-R and I'm going to get a set when they're readily available. The T1-S is an amazing tire so since you've got the rims coming in next week and you probably don't want to wait for the rubber to get here, the T1-S is still a good choice.
Any of your choices for A/S tires are good ones. I'd probably either go Perelli or Toyo and I don't really have any preference over another. I'd go for whatever is cheaper.
Design By Force
Thanks for the input...
what about things other than snow? are the summer tires worse on cold pavement, and will they handle WELL in heavy rain?
Do you know what the T1-R's will offer in comparison to the T1-S's?
The difference in price on the A/S is $186 for the Proxes 4 on sale from 230, or the Pirelli's for $129. Is the Toyo really that much better of a tire?
Photography Nerd
Sounds like a pretty major redesign:
Originally Posted by another forum
...stiffer shoulders, better tread design for braking, lower noise at worn stage, longer life, new tread compound, major improvement in dry handling
As far as the A/S tires are concerned, we have members with both types. I'm sure they'll be able to address your questions a little better than I can.
Depending on the rim offset the 235's with the A-Spec should be ok. Hell I didnt think 235's would fit on a 7.5 rim but I guess so. The TL A-spec rims are sick 18x235 on an 8 inch rim. Would look awesome on a TSX if it fits.
Design By Force
Someone on this site has them... but i thought they were 8.5" The new Ron Jons i just got are 7.5"
I think i am going to go with the proxes 4... from what i have read, you really don't give up much for the A/S rating on these particular tires... unless i can be convinced that a summer tire like the T1-S's will far outperform the proxes 4, i am not willing to give up my car for the few days a year that it does snow.
Design By Force
Originally Posted by JTso
Why can't you simply use the stock wheels/tires for the few snow days?
Bye TSX, hello domestic?
in general, people who use different wheels for winter slap them on before snow season and leave them till it stops. so i'll have mine on for nov-mar.
08 MDX with Sports
Here's the site for the T1-R: http://www.toyojapan.com/new_tires/index2_1.html
The T1-S is no slouch so this should be quite the tire. Wet handling is not a problem with properly designed summer tires. The T1-S and T1-R will stick like glue in the wet.
I have 225/40/18 P-Zero Nero M&S and used to have T1S before. They both are excellent. You give up a bit cutting edge preformance but returning a way more comfortable and quiet ride on PZero. And also PZero is almost half the price of T1S. But PZero has a very rounded edge that make it didn't look good at all but if you have a aggressive offset and want 235 wide then it maybe a safe point for avoiding the rubbing. :blaze: BTW, I think Proxy 4 is almost the same price as P-Zero Nero isn't it?
I'd say the new T1-R looks more like the Dunlop SP Sport 9000 than anything. Care to post a pic comparison for those 2 Dan?
The T1-S is already an awesome tire, with the only complaints being soft sidewall and noisy, the two things they seem to have addressed with the T1-R.
Photography Nerd
Design By Force
Honestly, a comfortable ride is pretty important to me. the 235 should help, and i have a +50 offset so i think i should be ok.
The proxes 4 are much more expensive than the nero m+s, but it's also because the neros are on tirerack and the proxes would be bought locally at les schwab.
anyone ever get their tires siped? is this worth it?
Design By Force
Originally Posted by Newplay1
SP9000 are awesome tires.... 2 of my buddies have it (RSXs)
I used to have toyo FZ4 and they were ok...
Design By Force
In the past it seems people have liked the FZ4's, but after reading about the newer 4's, it just seems like an upgraded replacement. far better dry handling, and much better wet braking (i'm in seattle). They also apparently are quieter, have a bigger rim protector, and have a traction rating of AA. Just ordered me some, they'll be here friday.
check out the site Dan Martin posted earlier - http://www.toyojapan.com/new_tires/index2_1.html
I have Bridgestone Pole Position S-03's, 225/40 and there is no way in hell a 235 would fit on my 7.5 inch rim (with these tires at least). Called Bridgestone to confirm and they said the website was correct in requiring an 8" rim with the 235. Sidewall would be under too much stress due to the amount of flex needed to meet the rim. Said ride would be softer and load carrying ability would be compromised.
Just the website which gives the minimum rim width at 8". As for fitment, I should have said a 235 would fit but would look like crap (225's already look buldging)! I suppose we could fit all sorts of tire sizes on a 7.5 inch rim, 245/40's would fit if you "jammed" them on too. All I'm saying is just because they fit doesn't mean they're right. Look at all the tire manufacturer websites (Bridgestone, Michelin, Toyo) that say an 8" rim is a requirement for a 235 tire.) They're obviously not saying it without a reason.
Registered AssHat
Kumho also specs their 235 tires to fit on 7.5" rims.
I'm not arguing that people have fit 235's on a 7.5" rim, but why then an 8" requirement by most major tire manufacturers? Just answer me that...is there a conspiracy for us to buy an 8" rim, probably not. They have a requirement for a reason, just because your tire hasn't fallen off or blown-up doesn't mean it's running properly.
The S-03 in 235/45 for the 17" rims meet the Bridgestones specs. Bridegestone S-03 spec provided by Tirerack
