225/45/18 vs 225/40/18
Old 11-08-2004 | 07:49 AM
CrashK2Wu's Avatar
8th Gear
I am considering going with 18s. Anybody have experience with a TSX and 225/45/18? I know it is slightly larger than stock size but I think it might improve the side profile of the car by filling in the gap between the car and the wheel more. Would I still be able to lower the car? Thanks.
Old 11-08-2004 | 08:20 AM
Dan Martin's Avatar
Photography Nerd
235/40/18 is a better match to the OEM size. You should look for a 7.5" or 8" wide rim with at least a 45mm offset.
Old 11-08-2004 | 09:16 AM
CrashK2Wu's Avatar
8th Gear
Doesn't a 235 require an 8" rim?
Old 11-08-2004 | 10:14 AM
Dan Martin's Avatar
Photography Nerd
https://acurazine.com/forums/showthread.php?t=4500
Old 11-08-2004 | 10:17 AM
xizor's Avatar
Bye TSX, hello domestic?
no, many people have 235 on a 7.5" wide rim. And you won't be able to find 225/45/18 in many wheels at all, you're only reason choices are 225/40 or 235/40
Old 11-08-2004 | 10:41 AM
CrashK2Wu's Avatar
8th Gear
Thanks. Now I just have to find a rim I like with the appropriate offset. What are you opinions on these wheels:
Enkei ZR1 (40mm offset)
Ace Manta - Hyper Black Paltinum (42 or 48 mm offset)
Falken Torque 5 - Silver or Gunmetal (35mm offset - will it fit?)
G-racing Siegen - Silver (?? offset)
G-racing Saporro - Hyper Black (?? offset)
Old 11-08-2004 | 10:48 AM
Dan Martin's Avatar
Photography Nerd
We have a million threads on offsets. As I mentioned before, try to find something that is at least 45mm. People have gone as low as 42 but you're on your own at that point. Keep in mind that stock is 55mm.
Old 11-08-2004 | 12:25 PM
sol-tsx's Avatar
If you prefer the 45 series profile on an 18" rim, TireRack says that 215/45/18 works on the TSX. That's the setup that I am going to go with when I go Plus One.
Old 11-08-2004 | 12:31 PM
Dan Martin's Avatar
Photography Nerd
Why not go a little wider?
Old 11-08-2004 | 12:34 PM
CGTSX2004's Avatar
My guess would be if they're more interested in the look than the performance gain.
Old 11-08-2004 | 12:37 PM
joerockt's Avatar
Just dial 1911
42mm is perfect for an 18x7.5.
Old 11-08-2004 | 12:51 PM
corbs's Avatar
Baka Unco
I think because a 225/45/18 is next to impossible to find. Not many companies make them, although the 215/45/18 does exist.
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
sw20td06
04-02-2005 10:08 AM
Edr0e
03-26-2004 02:51 AM
Quick Reply: 225/45/18 vs 225/40/18
