18x7 +42 question
Old Jul 12, 2008 | 04:43 AM
FoBuLouS's Avatar
I called paypal dammit!!
18x7 +42 question
I got my hands on ROJA Formula 7 18x7" ET+42 wheels. Would these wheels fit on my tsx without any issue? Would they stick out from the fender? I want it to be a perfect fitment without any rubbing issue. My car will also be going to be dropped with H&R and Konis.
Also, if someone has ROJA wheels, does the oem TPMS fit on the wheels? Any comments will be appreciated.
Old Jul 12, 2008 | 07:54 AM
1TSXer's Avatar
Resident Metal Head
I think they should work just fine. They should sit almost flush with the fenders. I'm running a 18x7 with a 45mm offest on Koni's and Neuspeed Sports and I have no rubbing issues. You may get an occansional rub on the fender liner tab if anything.
Old Jul 12, 2008 | 11:17 AM
GTSX-05's Avatar
ASM 3G TL Type-S
I agree, you should be fine and I would jump on them. I am on 18x8's with +45mm offset, my wheels are pretty much flush with the front fender.
Old Jul 12, 2008 | 04:38 PM
tdottsx's Avatar
it depends on what size your tires are, 225 40 18? i was running 18*8 with 38 offset with 225 45 18 tires with a 1.7" drop and i rubbed alot.
Old Jul 12, 2008 | 07:51 PM
FoBuLouS's Avatar
^^^^^^ i think it's cuz you have 8inch width in addition to 38 offset. I think i'm going with 215 size tire cuz 7 inch width is too narrow for 225 width tires. Thanks for the help guys!
Old Jul 13, 2008 | 11:52 AM
chuson's Avatar
T.DoT P.I.M.P. lol
It's not depends on tires. The reason why you rubbed alot is you have a 18X8 rims w/ a low 38 offset; and your 225/45/18 helps to rub too due to the high sidewall.
I'm running 18X8 +45offset w/ 225/40/18 + a 2.5" drop (1 finger gap all around); and never rub.
For OP, don't worry about your rims and tires, for 18X7+42 and 225/40/18 tires, even w/ 3" drop you will NEVER see rub. GL on your rims.
Old Jul 14, 2008 | 01:43 AM
FoBuLouS's Avatar
okay thanks! One more question. What size tire do you guys recommend on 7" width rims: 215-45-18 or 225-40-18?
Old Jul 14, 2008 | 04:30 AM
1TSXer's Avatar
Resident Metal Head
I'd go with a 225/40. A 215/45 is too tall for my tastes.
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
