View Poll Results: How many people Left foot brake in the TSX
Voters: 63. You may not vote on this poll
Left Foot Braking
#41
Originally Posted by PixelHarmony
..., but after my girlfriends friend got into a fatal accident I sorta backed out on wanting to learn.
http://www.tailofthedragon.com/
http://www.sylviastuurman.nl/
And, see http://www.sylviastuurman.nl/motor/accidents/#rr
I love British humor, "The truckdriver is an Englishman. 'Ah, a Roadrunner, my very favourite bird'"
#42
Originally Posted by Jim Holloman
Correct. That is why you could shift gears while your left foot was hanging out. The kick starter was also on the right side on most bikes. If I recall correctly, the starter was attached in the center on the BMW's and extended to the left side. You you would stand on the left side of the bike to start it.
I have also never been a fan of electric starters on bikes. I would rather kick start and not have the extra weight of an electric starter and larger battery.
Here is something else you may not know. A few of the bikes had compression releases to reduce the compression and make kick starting easier.
Do you recall seeing any Harleys (Harley 74) with a gear shift level up against the left side of the gas tank. You had to take your left hand off the handle bar to change gears. I believe the clutch was on the left side and the brake on the right side. That was no speed shifting with that arrangement.
#43
TSX JIGALO
I used to do it when I sprained my right ankle and I had to drive!!!.. yeah I know I was nuts but I really had to see the doctor and I am too cheap to get a cab...It wasnt bad just takes time to getting used to the timing when braking other than that it was easy.
rockyboy
12-06-2022 02:29 PM
