Wiper fluid shoots bottom of windshield...adjustable??
I have an 04 with 43,000 miles and whenever I turn on my wiper fluid, its a huge waste because the wipers come up before the fluid hits the windshield and on the way down it just pushes all the liquid down. Not a big deal but I would think it should shoot 1/2 or 3/4 the way up the windshield. have any of you ever adjusted this? Thanks for any help/suggestions!!
Easy -- anything small and thin (pin, toothpick, etc) that fits in the nozzle holes will work. Just a heads up, a VERY SLIGHT change to the angle is really amplified on your windshield, so it will take some trial and error.
I am curious to know if you were able to successfully adjust your washer nozzle? I tried this on my 2004 as I was also frustrated with the low spray angle and the waste of fluid. I didn't have much luck. As I recall, it was touchy and I couldn't achieve much improvement. Please let us know how you did.
So I was fiddling around w/ my washer nozzles this weekend and could not figure out how to adjust them. I did what 78transam said and used a small screwdriver and placed it both above and below the "horizontal slot." Wouldn't budge. I tried pressing pretty hard everywhere that WASN'T the horizontal slot, and nothing. It seems like it's all fixed plastic around there and nothing's adjustable.
Any other methods to try from anyone else? Thanks.
I asked my dealer about this and they said they could adjust it for me. Well when I got the car back I found out that whatever they shoved in there to adjust it totally bored the hole out and now it just shoots a solid jet of fluid in the same place it used to spray: the black plastic below the windshield. Awesome.
I'll probably buy a new nozzle thingy in the spring and try fixing it myself. They do not appear to be adjustable at all on 04's anyway.
That's why I chose to use a flat blade screwdriver to rotate up or down the nozzles. The nozzles on my '05 wouldn't budge initially but freed up a little as washer fluid dribbled back into the nozzle. Maybe a couple drops of penetrant may help free things up.
It's good to know the techs at my dealer are such incompetent apes that they can't accomplish such a simple task requiring a delicate touch. They've got the tightening down fasteners to the point they will never be able to be removed again covered though.
I guess if they can't use 700 ft-lb air guns on it, it is something that can't be done!
it's actually probably the best windshield sprayer I've personally
used to date. I like it much better than the ones that shoot
3 streams out of each nozzle. the one on my TSX sprays
a perfectly even, perfectly aimed fan with just the right amount
of fluid. I guess I will consider myself lucky.
not sure about the rest, but my 08 is perfect.
You aren't by chance visiting Spitzer Acura, are you?? If so...I totally know what you're talking about. Smail Acura in Greensburg isn't any better either. Actually, they may be worse.
Nope, Baierl Acura in Wexford. I'm pretty much done going there for service. They always assume I'm some dumb ass who will just swallow their bullshit and open my wallet then when I start digging into the issue they get pissy with me like they can't believe I would even question what they're telling me. Their prices are insane on top of it all.
Adjusting 04 spray nozzles
My nozzles were way low and small jets. I cleaned them with a small wire and used a very small flat screwdriver to adjust them (they are a ball and socket design). I now have a broad fan of spray across the windshield. Took me 20 minutes or so. Would have been 5 if I had a helper hitting the spray lever.
I too had this issue. I tried cleaning the nozzle with a pin and was not very successful. So I went to my kitchen and got a bottle of lime-away (calcium and lime cleaner) and added a couple of ounces in the windshield cleaner water bottle. I then operated the spray and soon the lime-away soon cleaned out the nozzle and it works great again.
Works for me!
Works for me!
MrHeeltoe
20
02-23-2023 01:54 PM
SidhuSaaB
05-30-2020 12:40 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
