Window up module problem
Old Jun 24, 2006 | 01:50 PM
LoveMyTL-S's Avatar
I just installed the Window Up module and it doesn't work. I want to check the wiring. I have a 04 TSX.
I connected as follows:
Black to Solid black wire
Blue to Yellow w/black stripe wire
Yellow to Yellow w/silver dots wire
Red to Green w/white stripe and Silver dots
(all in harness behind speaker)
Green to White w/red stripe and Silver dots
(arm rest window control harness)
Any help would be appreciated.
Old Jun 24, 2006 | 03:08 PM
oaksnutz's Avatar
BDI aka Booty Man
I haven't been able to get mine to work either. I tried 3 times already and nothing. I noticed that my horn no longer honks upon lock when the module is connected. After I removed the module the honk upon lock worked again.
Old Jun 24, 2006 | 03:10 PM
LoveMyTL-S's Avatar
Hmmm, not sure why the horn would not work. You didn't cut any wires did you? I just stripped and sliced. KP wants me to check my wires with a voltage meter. I guess that is my next thing to try. Mine locks and windows go down normally from fob, just no windows up?
Old Jun 24, 2006 | 04:49 PM
oaksnutz's Avatar
BDI aka Booty Man
Nope didn't cut any wires.
Old Jun 24, 2006 | 04:50 PM
Masterpoolcat's Avatar
Those are the exact wires I used and it works like a charm. I also have a 2004 TSX. Maybe you blew a fuse. Check your fuses.
Old Jun 24, 2006 | 06:25 PM
LoveMyTL-S's Avatar
I'll check the fuses. But everything else works, down window with FOB and up window with key in door. Thanks
Old Jun 24, 2006 | 09:53 PM
CGTSX2004's Avatar
I got your PM, so this is in addition to what I wrote in it.
When Reach and I worked on it, we discovered that there were a number of white with red striped wires. We had to try a couple before finding the right one. Make sure that you have tapped the correct one to attach the green wire from the module.
Old Jun 26, 2006 | 06:39 AM
LoveMyTL-S's Avatar
Okay, thanks for the tip. I think that wire needs 12vdc.
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Rachel Lu
Sep 27, 2015 09:53 AM
HeloDown
Sep 8, 2015 06:51 PM
sputik
Sep 7, 2015 01:40 PM
