Will the VSA activatewhen rear wheels slide?
Hi,
I have a question here. Will the VSA kick in when the rear wheels starting to move sideways? The reason I'm asking is because now it's snowing in Vancouver, and when i'm driving on the snowy roads, i do not feel that the VSA is kicking in as my rear wheels slide. In contrast, the VSA does kick in when the front wheels starting to slide, and the VSA activation light is blinking.
In the easiest way to explain it, I believe VSA works on your speed sensors and if speeds all of a sudden pick up at either of the front wheels, than the computer will make the engine send less power to the slipping wheel therefor you'll get traction on the non slipping wheel.
Originally Posted by Chris55
Hi,
Hi,
Originally Posted by ACURA
The traction control component of VSAŽ uses sensors that monitor the front wheels and computer-controlled modulation of engine power and front brakes to help prevent wheel spin when starting out or accelerating. If the sensors detect excessive front-wheel spin during acceleration, the traction control function automatically closes a secondary throttle valve until wheel spin stops. This helps the TSX maintain traction during acceleration and helps the driver retain steering control, even when accelerating on slippery surfaces.
mada51589
Jan 9, 2025 04:40 PM
