Why you should change your cabin pollen filter
#42
Originally Posted by jlukja
http://www.vtec.net/articles/view-ar...icle_id=355466
Its for a 7th gen Accord but I think the procedure is the same
the two clips on the inner wall of the glove compartent you can take out. Just use a flat head screwdriver and pop those out and the glove compartment will release.
#43
Originally Posted by Savio
It's not...
#44
I compared the Acura filter with Wix filter (From www.filter1.com)
The Acura TSX filter is better quality. It has more ribs then the Wix. The material looks a little better. I got the Acura TSX filter from handa-accessories for something like $34 dollars. The Wix filter was a little over $12 dollars. I guess you get what you pay for. I am not sure if the tickness of the filter would make much off a difference. I've never tried the TL or Honda Cabin/Pollen filter. I believe someone said it is the same as the Acura TSX filter and that it cost around $16-$20 dollars. Can someone confirm the TL and/or Honda Accord filter is the same as the TSX?
#45
#46
guys, i just got my TSX a week ago and the carfax said it had been in for service 5K ago....is this service part include the changing of these filters? Or should i replace these...BTW I checked the oil and its full and looks clean. OH, also, i dont have a users manual..where can I get a manual for a good price?
#49
#50
Changed mine today @ 23K
I got the cheap one - WIX (#24815 @ $9.75) from fleetfilter.com (made in Taiwan)
WIX one has 32 pleats, factory one has 44 pleats and a plastic "spine" in the middle
![](https://static.flickr.com/84/227656005_f7ba47a83d.jpg?v=0)
People say factory one is stiffer, I think it's combo of:
1) it's clogged with dirt & whatnot
2) More pleats within the same dimension
#51
#58
Originally Posted by TSeXy_Grl
what are the instructions? i'm not car savvy but i have a friend who can change mine. i just need the instructions. i have a 2006 tsx and it's not in the manual.
thanks.
thanks.
You will find a link to this DIY thread by davidspalding: https://acurazine.com/forums/acurazine-clubs-meets-15/car-meet-houstonians-39992/
#59
ASM 3G TL Type-S
I tried replacing my cabin air filter also…inspired by this thread, lack of reading on my behalf I managed to break the ‘shock’ that compresses, and makes the glove compartment slide down easily. Anyone know how much the part would be or what part I am looking for? Would I be able to change this myself? Or is the dealer going to charge major $$.
#60
boost owns
GOOD LORD, those pictures are nasty. I wonder if mine has ever been changed, I just rolled over 40k. Hopefully Acura did it at my 30k service in 2006 but I don't know. I need to look in to this.
#61
my acura sanctuary
25k and mine was Gray Gray Gray and black. More nastyness. Thanks for the info. Picking up Honda Accord filter tomorrow $25 at dealer. Online is cheaper but...
#62
Although I'm only at 17k miles on my 06 TSX, it's 2 years old, so with a sale on Purolator BreathEasy filter ($20 reg, $16 on sale), I decided to replace mine.
Removal wasn't as easy as everyone said. Although I could get the left side stopper down, I couldn't do it with the right side. I didn't want to risk breaking it, so I ended up removing the 2 screws on the hinges, and basically removed the entire door. After that, no problem getting to the filter
The filter was a little long, and didn't fit well (it looked like they literally just cut it down from a longer filter). Two snips with scissors, and it fit perfectly
Compared to the picture at the beginning of the thread, my filter was at least 50% darker, maybe close to twice as bad. I think in the future, at least for me, changing it every year might be more appropriate.
Jeff
Jeff
#63
Jeff
Jeff
And I agree that it should be a yearly change. It may depend on where you live and how much you use the car, but certainly if you're anywhere where there's winter (like here in the North East), the winter dust alone will make a change every spring a good habit to get into.
#64
The filter was definitely missized. There was maybe a 1/16" of border at the end (without filter between it) that caused it to go in so tight originally, it caused that top portion of the filter to 'V' (bend inward) in order to fit. Once I trimmed that off, it was fine. Maybe I'll try a different brand next time, and see if it goes in smoothly.
I had read most of the posts first on the glove box removal, and even though I had no problems with the left side, I just couldn't get the right side in enough to get the stopper past the opening. I'm sure it took longer to pull off the door(really align it when I put it back on) than someone might be able to just bend it out. On the other hand, I knew the risk of breakage was almost nil my way, vs a definite possibility if I kept trying to bend it.
I live in a city, and have a mix of city and highway driving, but I didn't think it was that bad to make the filter that dirty (I still have it, I'll see if I can upload a picture of it.
Also, one suggestion was to put a dryer sheet on the filter to provide a nice smell for the car. Originally I thought that might be a good idea, but seeing how dirty my filter was, and obviously how important every square inch of filter material was, I didn't want to do that.
Jeff
Jeff
#65
Jeff
Jeff
#66
Make a hole, coming thru!
From what I've seen, the Wix, Purolator (sp?) and Napa filters are fine. And FWIW, I'm finding that changing the filter every 6,000 miles is a Good Thing.
... The filter was a little long, and didn't fit well (it looked like they literally just cut it down from a longer filter). Two snips with scissors, and it fit perfectly
![Screwy](https://acurazine.com/forums/images/smilies/screwy.gif)
Originally Posted by Simba91102
I agree with a dryer sheet permitting less air flow. Also, my experience with using one for fragrance has been that it will last a couple of days at best.
#70
Originally Posted by npolite
www.acuraautomotiveparts.org has the TSX one for $30.76 and the TL one for $16.21.
Pay $30.76 only if you like telling passengers "your cabin air is continentally scented."
![what](https://acurazine.com/forums/images/smilies/what.gif)
#71
Originally Posted by davidspalding
I understand that the Acura filter for the Japan-built TSX is by micronAir Europe (so it's imported), the TL/Accord filters are made by micronAir US. Same filter basically. UNLESS the TSX one was micronAir's "combi" charcoal impregnated model.
Daaaaaang, Si2TSX, that's one ugly filter. I'll bet your blower is working a lot better/quieter now. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
#73
Just replaced mine this weekend. Bought the Honda filter for $21. Took me less than 10 minutes, and I'm a girl...
My car has about 50 K on it and it looked pretty nasty...
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
#74
Hi,
I replaced my cabin air filter ..thanks a lot to this thread..
And is there another filter "Air Cleaner Element" ?? I tried to open the Box that is next to the batter (towards the Brake fluid tank) and one of the bolt i couldn't urscrew ..Is there a filter in it ??
Mars
Mars
#76
Originally Posted by mars
Hi,
Mars
Mars
