Wheel / Seat Juddger fixed unexpectedly
Old Apr 26, 2011 | 05:03 PM
phishie's Avatar
Recently picked up an '05 TSX and off the bat noticed the feeling of brake judder in the steering wheel. Not long after I noticed the same feeling again but when I wasn't braking.
The feeling of non-braking steering wheel judder would come and go at certain speeds - typically at 60-65mpg, 70-75mph and in the 80+ mph range. I assumed it was due to an alignment issues so I got all 4 wheels rebalanced and a 4 wheel alignment. Steering definitely tightened up after that but the feeling was still there. Then I chalked it up to an axle or unknown reason and figured I'd get to it eventually.
Fast forward a few months to this week and I think may have solved it.. albeit unexpectedly. Yesterday evening I decided to try out Seafoam hoping to get some better MPG (currently getting 19-22MPG in city). I put 2/3 in a nearly empty gas tank, filled it up with premium (as I always do) and then fed the other 1/3 into the vacuum tube when I got home. Woooweee, got some good smoke when I fed it in the vacuum tube.
Now it's only been a day, but so far the steering wheel judder at certain speeds seems to be almost totally gone! Does this make any sense? Could a dirty fuel system cause excessive engine vibrations leading to the steering wheel judder I experienced? This seems hard to believe but results are hard to argue with.. thoughts?
Old Apr 27, 2011 | 10:57 AM
phishie's Avatar
Well after another day driving around it still seems the steering wheel/car vibration has been significantly reduced although still slightly there.
I'm beginning to think it may also be due to loose cv/axle as described here: https://acurazine.com/forums/1g-tsx-problems-fixes-128/shaking-vibration-only-when-accelerating-781497/
Although prior to the Seafoam I recall feeling the vibration at certain speeds while deceleration coasting as well as under acceleration.. which wouldn't point to axles, right?
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
Phambam12
Sep 6, 2015 06:57 PM
