Vibration at idle
Vibration at idle
Hey guys, I've noticed that my TSX vibrates a lot at stop more after installing the DC sports header and the Greddy Evo 2 cat-back. Just want to see if anyone else experiences the same thing and if there's anyway to decrease the amount of the cabin vibration. I'm going to be changing the spark plugs soon to see if that helps. Thanks.
I have a topspeed, so essentially a DC as well. I do feel some more vibration but I believe it is the lack of support. I'm going to wrap use thermal wrap on my headers and a metal strip to give additional support around the cat. Dunno when I"ll get around to it but I'll let you know if it fixes the vibration.
Coincidence, i guess; I put my tsx up on jacks as we speak. my exhaust rattle is getting a little annoying. I'm putting some of that white grease in locations on the system where the clearance is close/tight, run the car and see where the grease might rub off from the vibration.
I noticed that while on JSs, that applying a slight pressure to the joint where my RT cat and CT header connect, that the rattle disappears. A shorter hanger nearest that couple is whats needed to stop the rattle. Its a subtle 'sag' but the bolts are tight.
Stock will still vibrate slightly if you're in drive and have the brake pedal pressed. In park or neutral it should be very very minor if at all. If it's an AT, you won't ever not have vibration when in drive. Vibration will be especially bad when the engine is cold. When the car warms up and the rpms settle into the 6-7 range, you'll notice that the vibration is much softer while stopped in Drive. But the vibration does increase on and off when the A/C condensor turns on and off. For some reason that makes the vibration increase while it's running. It's subtle if you're not looking for it, but it's there on all the stock A/T TSX's I've ever driven (06,07,08).
Is the vibration at start up (and in gear) meant to be worse if there is a large electrical load on car ie when start up on a cold night and then need to turn on headlights, rear defroster, A/C etc?
cabin vibration is common in i4 engines!! v6 not so apparent but if youre really paying attention, you can feel it too!
the tsx's cabin vibration is controlled very well compared to other i4 i have sat in.
Did you ever solve the problem? I have a 2008 tsx that has a rough/vibrating & erratic idle when I am stopped/ on the brake and I've taken it to the dealer 3 times with no solutions....please let me know if you figured this out.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
