Vibrating low rpm between 1500-2000
Old Dec 8, 2012 | 07:55 PM
qedi's Avatar
3rd Gear
Hi, I recently purchased a used Acura TSX 2004 2.4L Automatic 122.000 miles on it and I have a problem with it.
There is a big vibration in the car while driving it automatic mode (not in the manuel tiptronic mode) and when it works in low RPM levels around 1500-2000. I'm not sure if the transmission mounts are causing this vibration problem.
The other thing is that the transmission has a 2 seconds delay when shifting to reverse from parking and or shifting to drive from parking. When I shift to reverse, I have to wait 2 seconds until it kicks it into gear and its jumpy.
Could the problem result from a bad transmission solanoid valve, or could the problem be because of transmission mounts? I hope this is not a mechanical transmission problem.
Old Dec 9, 2012 | 02:04 PM
TexasHonda's Avatar
If the vibration is primarily noticed when accelerating fairly hard, the CV axles may be the problem. Others have had this problem, so search will find the threads w/ info.
A delay can be normal for some trans. I have a 94 Accord that does this a bit, but has not affected the shift quality. It has 250K miles It's aggravating but manageable.
good luck
Old Dec 9, 2012 | 02:41 PM
qedi's Avatar
3rd Gear
good luck
thank you for your reply, but there is no problem with CV axles. i am still searching what can i do...
Old Dec 9, 2012 | 11:16 PM
Rocket_man's Avatar
Summer is Coming
Do you know when the last tranny flush was done? Maybe it just needs a good flushing.
Old Dec 10, 2012 | 05:23 AM
qedi's Avatar
3rd Gear
I want to add some more information.
I live in Turkey, so the car brand is here "Honda Accord". After hard work i realized that my car is Acura TSX in the north us and in the other countries (except australia and europe).
I meet with a repairman about transmission. he said that transmission should have complete diagnose. and its costs about 2000$ US. (here is very expensive everything, and i know that he i no sincere). thats why i am seaching opporunities about the transmission.
my common question is i have this problem only in automatic mode. after we tested "solenoid assy,linear B" with computer , it seems working properly. (solenoid assy price is here about 800 $ US). I want to know that can solenoid assy be broken without any signals like engine fault light??? I mean can seem working "ok" in the computer based test, even if it is not working.. If not i have to pay 2000 dollars to complete repairing of my transmission...
I want you to share your precisious comments.
Thanks.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
