Tsx 04 serpentine belt
I recently change my serpentine belt and theres noise when starting up the car and acceleration, the noise goes away after running the car for like 30 min straight but after turning the car off comes back when you turn back on
There was no noise before i just decided to change it because i had the car for 3 yrs i hadn't change it before
What can cuase that noise the belt or did i not install it right?
how can i fix it?
how can i fix it?
Check the belt and check the belt tensioner is in the normal margins.
Might need to relax the belt, pull on the belt tensioner like you would to change the belt, maybe give the belt a little turn if you can, see if the new position sits better.
I tried it but no luck the noise is still there i took to a mechanic he said the tensioner need to get replace but i feel like noise comes from the power steering pulley, i dont feel to 100% positive about switching the tensioner
09 TL SH AWD /w TECH
alexpapas90
02-28-2016 06:44 PM
Skier4lyfe303
02-18-2016 01:23 PM
