Trying To Find Solution to Intermittent Clock Display
I am having a problem with my 06 Navi TSX.
The LCD sitting up above my touch screen - on top of the center console (the LCD with the clock, HVAC Temp numbers etc) is intermittent - it will fade out or go off depending on temperature and bumps in the road. To see the time I can hit the top of the dash and it will sometimes light it back up.
Seems like a much different problem than the "Center Console Lights" problems I have found talked about and covered here. All of my other dials and lights are fine...
It seems like a loose connector - as everything works. I would love to fix it without much hassle, but don't know where to start.
Anyone have any ideas???? Thanks!!!
Normally I am not one to answer my own questions...
I have been looking for a fix to this problem for several months. I finally decided to post a request for help - then after posting did some more digging and searching. I found some people with the same problem with TL's and RL's but no TSX's. After about an hour of looking at those fixes and the TSX center column fix I decided I had a shot at fixing the problem by taking out the center NAV unit and trying to get to the top clock LCD.
I found one of the DIY Center Console Fix threads and decided what the hell - let me take it apart and see if I can get the LCD out and try to figure out what is wrong.
It is now fixed!!!
I took off the 2 dash trim pieces, the hazard button, and then finally pulled out the NAV unit from the dash. This allowed me to get to the top display by removing 2 additional screws just above the vents. The clock display came right out with just a little tug. It had one green wire connector on the back side. I then took the entire LCD assembly apart to look at the PC-Board. The pins for the connector had pretty bad looking solder around them, so I took them into my work and used our good soldering iron and microscope inspection station to touch up the board.
After I reassembled everything it now works!!!
I only had 2 mishaps trying to get the trim pieces and the NAV unit out of the dash. The long passenger side trim piece ended up with a tiny hairline crack on one area while I attempted to pry it off - you can't even see the crack once it is put back together. I also couldn't initially find the small hex screws way up inside the console and kept trying to pull the NAV unit out to no avail. Once I found the two small hex screws, and removed them, the NAV unit came right out!
It is now fixed!!!
This thread has good images of the correct service manual pages showing the steps I used to get the NAV unit out and get to the HVAC-Clock LCD...
https://acurazine.com/forums/problem...ailure-925093/
