Trunk release button stuck
Weird thing happened.... You know that button under the trunk lip? Well it stopped working. Whenever I press it to pop the trunk open from outside, it doesn't budge. I checked the trunk lock switches inside the car and everything is unlocked meaning the exterior button should release the trunk. Is this button electronically controlled? Should I have the dealer check it out? Thanks.
Where's the trunk switch at in the glove compartment. Mine recently quit working (along with my pass front door lock) but I may have bumped the switch while changing my cabin filter.
Check the left corner inside the glove box. If you feel for it, you might rub against the switch without knowing because it's very discreet. In that case, just look in you glovebox on the left side and you'll find it.
SidhuSaaB
05-30-2020 12:40 AM
justin.w13.walker
09-22-2015 02:21 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
