Trunk making noises
Old 10-08-2005 | 11:04 AM
mpio806's Avatar
Trunk making noises
My trunk is making clicking noises whenever i turn my car, it seem to be the metal adjusting. I can't figure out where the noise is coming from, the hinge holding the trunk door to the car is covered by this plastic thing. Does anyone know how to fix this problem?
Old 10-08-2005 | 12:36 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Make sure you don't have loose parts in the trunk. Check around the spare tire area.
Old 11-03-2005 | 11:21 PM
TimSX's Avatar
I have the same problem. A "clank" when I make a hard turn. I had the feeling it was a part rolling around since it would only make the noise when I turned in the opposite direction from the previous noise. I also hear a creaky noise and/or clank in the truck area when I hit bump. I just pulled the spare out thinking the dealer might have dropped a screw when mounting my license plate. Nothing. Will have the dealer check this eventually.
2005 TSX AT w/o Nav
3000K
Old 11-03-2005 | 11:41 PM
afici0nad0's Avatar
bad spot welds from the rear cross member in the trunk area...
lash it with wd-40, and you'll be good to go...
https://acurazine.com/forums/showthread.php?t=26392
http://www.acura-tsx.com/forums/showthread.php?t=23667
pics are available on these links, so it'll help you out a lot.
Old 11-04-2005 | 08:34 AM
moda_way's Avatar
also check the torsion springs in the rear to make sure they aren't creeking.
02-25-2020 09:57 AM
2012wagon
09-29-2015 04:21 PM
PortlandRL
09-14-2015 12:01 PM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: Trunk making noises
