Steering wheel shakes
Old Jul 8, 2004 | 11:28 PM
hata_teru's Avatar
Hi,
Recently I experienced the steering wheel shakes when I brake on high speed, what problems causes that happen? Please advised.
Old Jul 8, 2004 | 11:31 PM
CGTSX2004's Avatar
That would be rotor warp. Does it happen at slow speeds as well?
Old Jul 8, 2004 | 11:45 PM
hata_teru's Avatar
Hmm...not very noticeable at slow speed..maybe a slightly shakes.....but when I brake at high speed...the steering wheels shakes pretty bad.....
If the rotor is warp will the warranty cover or both front rotor need to be replace? In case the rotor need to be replace, should I forget about going back to stock rotor and go for the aftermarket ones.
Old Jul 9, 2004 | 10:37 AM
TJs TSX's Avatar
Were you easy on the breaks at the first 200ml? Have you ever slam on the break recently, or quite a few lately?
If so, it's a user's error and that might be out of your pocket spend, depend on how good your relationship with the dealer is.
For the after market rotors, you still can damage them, they just a bit less porne to wrap than the OEM ones since they're either sloted, drilled, or both. I would go for the after market since they're just a few bucks away from OEMs. If you do get the slot type rotors, make sure you get the one that the slots doesen't go all the way to the outer edge of the rotor, other wise yours would wrap again even easier!
I would go to the dealer and find out asap before I damage my tires too and see what they have to say. Good luck.
Old Jul 9, 2004 | 10:41 AM
CGTSX2004's Avatar
Going aftermarket may be a way, but rotors are rotors and if not used properly can still be warped. You should start be re-evaluating your braking practices. Also, for the most part, dealers will charge you for work on rotors and brake pads. However, some people have managed to convince Acura that the rotors have durability issues. Run a search on the forum and you'll see what I'm talking about.
Old Jul 9, 2004 | 12:56 PM
blueingrid's Avatar
There could be a couple of causes:
1. Incorrect torque on the lugnuts. This causes the rotor to slightly bend when pressure is put against them by the pad. Many heatings and coolings later, and you've just reformed your rotors! Wheels been rotated, changed, etc lately?
2. Hard brakes followed by constant braking. (Think, fast stop at a stoplight). You're superheating the rotors then blanketing that area with the pads (holding down the brake), making them cool at a different speed than the rest of the rotor. Hello, Mr. Warp.
3. The rotors are junk, in which case, Acura should have a TSB out about them. Since I don't see many other complaints on this one, I would guess it's either 1 or 2.
1. Always either torque your nuts yourself, or make sure whoever does, does it to spec.
2. If you have to brake hard to make a light, put it in neutral and get off the brakes. You'll still warp some from the uneven cooling, but at least it will be minimal.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
EvilVirus
Dec 10, 2015 07:38 PM
04tler
Sep 10, 2015 04:03 PM
MyKids&Cars
Sep 2, 2015 12:03 AM
