Squeaky Brake
3rd Gear
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
Hello! I have a 2006 TSX with 36k miles. I commute 60 miles round trip each day. The brake started making this soft high pitch squeaky noise at around 31k miles whenever I brake at slow speed. I also noticed that the sound becomes slightly more noticeable and frequent after being in the rain.
Anyway, I brought my car to the Acura dealer when I first noticed this issue. They told me that the rear brakes of all TSX tend to wear out much faster than the front and it's a common issue. The dealer told me to replace the rear brake at ~ 35k and front brake at ~50k.
So now I'm at 36k, contemplating whether i should spend $200
on replacing my rear brake.... What do you guys think?? Your inputs are greatly appreciated!
![what](https://acurazine.com/forums/images/smilies/what.gif)
No way for $200. Are you somewhat mechanically inclined? If you are, you can do it yourself. You'll need tools though, but it's not hard to do a brake job yourself. Plus, there are many after market brake pads better than OEM.
3rd Gear
Girl= no tools. so I don't really have an option...
I'll look into the rotors part...
I checked with a local mechanic and this is what he told me... "normaly the rear pads last longer than the front, when you brake all the weight of the car goes forward and transfers to the front wheels." That's what I thought too... Doesn't this contradict what the Acura dealer told me (change rear brake at 35k and front at 50k)?? I'm confused!
I checked with a local mechanic and this is what he told me... "normally the rear pads last longer than the front, when you brake all the weight of the car goes forward and transfers to the front wheels." That's what I thought too... Doesn't this contradict what the Acura dealer told me (change rear brake at 35k and front at 50k)?? I'm confused!
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
If you search around on this site you'll see many owners reporting that the rear pads wear faster. If you've never had problems with your brakes and you were happy with their performance then there is no reason to go to other/aftermarket brands. Find a locally owned brake shop or even a respected national chain and get a quote for the labor. Then check on-line prices or look on e-bay for genuine honda replacement brake pads (Acura of Escondido or Lynwood Acrua both sell them).
Maybe you didn't hear the dealer correctly or they are just BSing you.
First off squeaking brakes occur when there isn't sufficient molykote grease on the shims which are on the back of the brake pads. If someone takes off the caliper sometimes this is enough to have the grease flake off so that could be what happened in your case.
If the pads squeak when you are driving and they stop when you brake, that is your wear indicator telling you it is now time to change your brakes.
The dealer should have told you how much padding is left on the back and what the limit is. If they didn't call them back or take a look at the pads yourself. You should be able to see how much is left with a flashlight.
Yes the rear pads do wear faster then the front as there is less material on the rear versus the front.
You never need to get your rotors resurfaced. If they are warped you need new rotors. Resurfacing them will only make the issue come back again in the near future.
GWEEDOspeedo
01-15-2016 10:39 PM
lanechanger
10-13-2015 10:56 AM
