Slow start
Old Jul 25, 2017 | 01:28 PM
SteelTSX412's Avatar
Slow start
When I try to start my 2009 Acura TSX it starts pretty slow. So I took it to advance auto parts and had them run a test and they said the battery is good but the alternator will probably need fixed. So I took my car to my Acura dealer and they told me there is nothing wrong with the car. I just want to know should i have the alternator replaced or should i have the starter replaced?
Old Jul 25, 2017 | 01:36 PM
I'd try replacing the battery first and then the starter afterwards if the battery doesn't fix it. Alternator is last. I don't trust those testers at the auto places.. I've had good parts test bad and bad parts test good tons of times.
Old Jul 25, 2017 | 02:12 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Agree with thoiboi. Start with a battery - how old is it?
Has something materially changed with how quickly your TSX starts??
Old Jul 26, 2017 | 09:59 AM
TexasHonda's Avatar
Suggest purchasing a battery monitor ($15 Walmart, etc) to monitor battery voltage from cigarette lighter. Battery charging voltage (engine running) should be 13.5-14.5 V. If consistently below these levels then battery is likely being discharged and a new alternator may be indicated.
First clean each battery post connection thoroughly and inspect wires for corrosion. A bad wire can cause slow start speed.
good luck
Old Jul 28, 2017 | 02:32 PM
NZKIWIS's Avatar
5th Gear
I'm about to change my starter motor due to slow engine turnover during starting normally first start of the day or when the car has cooled down.
If replacing the starter you will also have to replace the intake manifold gasket at the same time as the starter is behind the intake manifold which I have be told why
the starter fails prematurely as it is subjected to heat from the engine where older Honda /Acura's had the starter motor on the side of the engine and not having restricted air flow by having
it tucked away. I think the electric's on these later model cars are the let down.
I will update this once I have changed out the starter next week.
Notahonda
May 17, 2023 05:31 PM
TLX15
Oct 25, 2016 11:35 AM
losiglow
Oct 19, 2016 02:13 PM
Dantes
Jun 10, 2004 01:03 PM
JZ
Jan 28, 2001 02:00 PM
