serpentine belt dealer cost?
Hey-
04 TSX 93K.
Car started making a noise under hood. My uncle took a look and said it was the serpentine belt. How much is the dealer (heart acura) going to rape me for? Should I do the alternator at this time too? Cost? Is is cheaper to go to Honda dealer instead? What about Firestone or some place like that. Never changed spark plugs. Should I do that now as well?
Thanks all-
FYI
does anyone have problems w/rotors rusting? Got new brakes and they asked how long was the car sitting? RESPONSE: I drive it DAILY!!!!!
Same burning oil issues as all..........
Navi: SHOT!!!!!!! Works when it wants.
04 TSX 93K.
Thanks all-
FYI
Someone stole "My Garage"
Plugs - not yet. 120k miles or so is the recommended mileage on those.
Serpentine belt - belt itself is $20-$30ish at most places (dealer is probably a bit more but I doubt by a lot). Labor shouldn't be more than 45 minutes - it's a dead simple job. Any independent shop can do this for you no problem, probably cheaper than the dealer. Just go somewhere you trust, or, bring it to the dealer and have them do it.
There's only one belt.
Alternator should be fine.
Rotors rusting -- on the flat part where the pads touch? Where? middle, very edge? Middle = not good = have brakes serviced. Very edges = normal(ish).
Is BANDO the original OEM brand, only $19.74? Or should I go with Dayco $24.21 or Gates Belt Tensioner $30.89 or Goodyear Gatorback Poly V belt $29.37
(all on Amazon)
Thanks Again
(all on Amazon)
Thanks Again
Never heard of Bando.
Dayco, Goodyear, Gates -- all good.
"Gates Belt Tensioner" is not a belt... it's a belt tensioner -- looks like a small pulley/wheel.
A friend of mine – a former auto tech who’s been a stay-at-home dad since early this year – replaced my ‘04’s serpentine belt about 5 months ago. I let him procure the belt, and he went with Bando. He assured me that there’s no cause for concern about Bando quality.
it's a car-drive it
the last service I had on my 06 tsx was at 114K+miles. They changed the spark plugs, engine coolant, oil/filter change, tires rotated/balanced, the cabin filter changed and did the power steering recall. They told me the serpentine belt was good and no need for replacement. I know I could have had it done cheaper but I trust this dealer and I have no desire to DYI.
El Cunado
I wouldn't write-off spark plugs. I bought my CPO '05 only having 43K miles and pulled one out at 50K. It was black (probably from the oil our engines consume). I replaced all four for reassurance. Hard to argue it's much smoother, but I know they aren't covered in oil/grime/soot. I'll look at replacing them again around 90K/100K miles.
I had mine replaced by the dealer in August; $401.00. I later found out from many that you can go to Discount Auto, buy the belt for $38, & they'll loan you the belt replacement tool for free, and it's less than a 15 minute job!
Hey-
04 TSX 93K.
Thanks all-
FYI
04 TSX 93K.
Thanks all-
FYI
so it isnt serp belt
Noise apparently is the water pump. Found out dealer cost for belt... it is $65.66 and $169 for labor. Total of $234.66. This is Wappingers Falls, NY Acura.
I paid $39.96 for the Bando belt I bought back in June. My '04 had 90,000 miles on it at the time. I replaced the original belt because I'd been hearing belt squeal for quite a few months -- primarily in the first minute or two after start-up. Of course, once I had the old belt in my hands, I could look at it closely. There were a lot of cracks in the "ribs" on the belt's interior surface, and a lot of tiny stones -- probably grains of sand would be a more accurate description -- stuck in the grooves, BUT I think the belt would have lasted quite a while longer. Still, I'm glad I replaced it, if for no other reason than to end the squealing.
it's a car-drive it
winkyyy
09-11-2015 04:40 PM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
