Seat Warmers Problem
Old Jan 28, 2013 | 01:26 PM
ads's Avatar
ads
I have an 06 tsx and I'm having problems with my seat warmers working. When I put it on the low setting, they seem to be working fine. However, when I switch it to high they do not work at all.
Does anyone know if this a common problem? I don't know if there is a way to troubleshoot so I can figure out what the problem is.
Old Jan 28, 2013 | 07:18 PM
Simba91102's Avatar
Old Guy
Haven't read of many problems with them here. I assume the problem is both sides (which is too bad since it kind of eliminates it just being a bad switch). Maybe some of our electrical geniuses here can help out.
Old Jan 28, 2013 | 11:28 PM
ads's Avatar
ads
The problem is only happening on the drivers side, sorry I did not make that clear. Also, the light comes on for both low and high but the seat does not get warmer on high. Just to be clear.
Old Jan 29, 2013 | 09:44 AM
Mskierki's Avatar
In our vehicles there are two different heating elements and wiring from the switch to the seat, one for high and one for low. I would guess that somewhere in that circuit there is an issue. You could try and ensure that at the connector underneath the seat you have:
a) continuity for the high wattage heater and
b) you have power when the heater is supposed to be energized.
There is one common lead bringing power to the switch to control both the high and low, so at least you know that nothing upstream of that is an issue.
The high wattage heater incorporates an automatic reset switch as a regulating device. While I am not aware of any problems with these they only will last a certain number of cycles. When they go they may open or short depending on the mode of failure. But either way I am not aware of any way to get to the part to service/replace it. (Unless you know an upholsterer)
Good luck and let us know what you find.
Old Feb 9, 2013 | 11:05 PM
dP-'s Avatar
dP-
You can check out this how-to from a TL. I believe it's very similar (haven't tried it myself yet)
http://joshsworld.com/cars/acura-tl-seat-heater-fix/
Old Feb 26, 2013 | 01:20 AM
jdowen2's Avatar
8th Gear
You can swap switches to help eliminate troubles.
Old Mar 30, 2013 | 01:35 AM
rollindom's Avatar
6th Gear
My 05 does the exact same thing. Low is fine, but high doesn't warm at all on the driver side. The passenger side works on high and low. Any luck finding the problem?
rockyboy
Aug 4, 2024 10:35 AM
d.lim
Sep 15, 2015 08:54 PM
Skirmich
Sep 15, 2015 06:41 PM
kareshi
Sep 3, 2015 03:38 PM
