Seat Heater Light
Originally Posted by TSX2345
Mine went out a few weeks ago on my 05, replaced under warranty
Originally Posted by FSU TSX
I just realized that my seat heater light for the passenger side is out !!!
has anyone else have this problem?
has anyone else have this problem?Trending Topics
Is it possible to just change the bulb and not the entire switch assembly?
I just looked at my receipt from when I took my car in they replaced the entire switch
Wheww Heww, i just replaced the bulb for the switch. Super easy and no stress at all... I bought the OEM fog lights from ebay a while back and never used the switch that came with it so I just took the bulb from that and it worked !
So Yes you can just change the bulb. You can get a bulb from here:
http://www.acuraoemparts.com/delray/...URA_TSX_BULB_A
Very simple to change out ! Thanks everyone for the input and help.
hmmmm....i think your probably not using the OEM fog light bulbs, as there are only 2 h11 bulbs in the OEM package. unless you fit an h11 bulb in your seat heater switch? i guess you are referring to the switch bulb in the aftermarket fog kit - or did you get the JDM OEM?
I'm using the light from the switch not the H11s. Of course they are not going to fit. The switch that came with the fog light kit has the exact same screw on type bulb that the seat heater switch uses.
rockyboy
Aug 4, 2024 10:35 AM
rockyboy
Jan 25, 2016 06:00 PM
EE4Life
Sep 11, 2015 10:13 PM
