Rubber seal scratches tint?
#81
Luke 1:37
Originally Posted by Savio
are these vertical scratches that bad?
will the warranty cover it?
can we get some pictures? or is it that light that it's really not that visible?
Warranty won't cover scratches.
I am about to install the Anti Scratch Kit, but I was wondering if the people who have installed it answer my question. Is this the part that you put the moleskin over?
![](http://img.photobucket.com/albums/v72/virtualbong/DoorPanel.jpg)
I'm also not quite understanding this step of the door panel removal? Some plastic pieces that aren't removed are supposed to go back on the door panel? Is this necessary?
![](http://www.chrishorne.com/albums/TSXspeakers/P1010014.jpg)
#82
Littering and.....
^^^ that is the piece you need to add the moleskin too. To answer your second question, those little white pieces of plastic are what hold the door panel in place. Sometimes they pull from the panel when you take it off and you have to put them back on the panel before putting the panel on the door.
#83
Luke 1:37
#85
Littering and.....
Originally Posted by virtualbong
Ahhhh, got ya. They look like the same plastic pieces that the side skirts use to lock the skirts in place, am I correct on this? If so, I would have to angle the pieces when I put it back on the door panel.
nope, you'll just have to slide them into place on the door panel and then they pop back into the metal on the door. No special angling required.
#86
Luke 1:37
#88
Luke 1:37
Yo Wil,
Take some pictures for us if you can....
it would be helpful for some of us....
Thanks!
-Savio
Thanks!
-Savio
#89
its not all that difficult, i think i have pics somewhere, i even figured out how to get those white things off if u so happen to get them stuck in there after u pop the door pannel off.
#91
Originally Posted by lodi781
Sucks....got my windows tinted last week, and sure enough, I look today and theres like 6 of 'em going up and down my window................
I got a couple here myself and also!!!!!!!!
my driver side window rolls up slow now...I'm taking that crap back to have them fix it...bastards...
#92
i got my windows tinted maybe 6-8 months ago and haven't noticed this problem...i have noticed, however, a periodic squeek from the driver's side window when i put it up or down, but it doesn't happen often enough for me to care too much.
#93
a dealer in ft.worth, tx is repairing the seals under warranty. replacing the seals w/new ones. my dealer in dallas won't replace the seals unless i purchased the tint through the dealer. they ONLY wanted $600 for a tint job!
#94
#95
Originally Posted by STL
If you have a TSX (or TL) that's had tinted windows for awhile and you don't have any scratches, please tell us what brand/model your tint is. Thanks...
#96
Rubber Seals
After weeks of bitch'n to Acura they finally fixed my problem with the tint. They pulled the door panels off and cut the rubber seal back some. They also put new tint on the windows even though I didn't have the tint put on through the dealership.
#97
#98
Originally Posted by Alin10123
That just seems like rubber though. How does that rubber scratch up the tint? If it's the dirt that gets trapped in there, if i just keep it extra clean... should that fix the scratch problem?
#99
Luke 1:37
btw. if anyone wants my moleskin, I'll sell it for $30 shipped (what I purchased it for)
WIL
#100
I got vertical scratches all over my tint but it's not a big deal to me.
However, I have this problem on driver side window when I try to close the window the glass will actually pop out of socket, because the rubber is bent and force the glass move outside the socket. I will need to go to outside of the car and manually bent the rubber to make space so the glass will stay in socket and close up.
Anyone got the same problem? Hwo do you fix it?
#101
#102
SidhuSaaB
05-30-2020 12:40 AM
InFaMouSLink
10-30-2015 09:43 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
